1. Let suppose, for the sake of arguement I have a 60mm dia brass disc, approx 1mm thick. Around the periphery, approximately 3mm in from the edge, I wish to cut 400 slots, each 2mm radially and 0.23mm wide.
    To index the disc it will be mounted on a backing sheet of some description and attached to a stepper which will be 1/2 stepped to give 400 indexable locations.
    So what to cut with? PCB routing cutters can get close to that level but would need careful depth control to get a consistent width. I've seen MicroCarbide endmills at 0.2mm on the web, but how realistic is that?
    Laser, spark erosion, what?
    You want one of these
    http://cgi.ebay.co.uk/RDGTOOLS-3-HSS...mZ260440292094
    or better still one with a smaller OD so it doesn't wobble. these will cut your slot in one pass.
    John S -
  3. Good try John, but the slots have to be a controlled length, not right to the edge.
    Oops missed that bit.
    What about doing this on a 54mm disk and pressing a 3mm ring on afterwards ?
    John S -
  5. laser - I doubt they will cut copper alloys
    edm - yes but at a cost
    0.2mm milling cutter in a top-notch cnc - no problem
    0.2mm milling cutter in a converted drill/mill 1 or two notches then snap...
    How about photo-etching?
    Laser will cut brass but the edge finish is $hit and at 0.23mm wide probably impossible.
    Spark eroder will do this no problem but you need a graphite or copper master and cutting this gives the same problems as cutting the slots.
    What is it for ? can the design be altered to suit a better method?
    John S -
  1. cutting a fine line
    By cubikoman in forum Tool & Tooling Technology
    Last Post: 19-02-2017, 09:04 AM
  2. Any tips for deep slots/profiling in aluminium?
    By m_c in forum Metalwork Discussion
    Last Post: 17-04-2014, 11:00 PM
  3. Taunton's Fine Wood Working
    By Lee Roberts in forum Wood Finishing Tips & Tricks
    Last Post: 06-04-2012, 10:49 PM
  4. Fine pitch Bolts
    By Normsthename in forum General Discussion
    Last Post: 13-08-2010, 10:13 PM
  5. Making a Jig
    By Wobblybootie in forum Gantry/Router Machines & Building
    Last Post: 06-06-2010, 10:17 AM
