Thread: Drilling holes on cnc
22-05-2018 #1
Are there special drill bits needed for a cnc?
I know my spindle has certain collet sizes so standard bits are unlikely to fit.
22-05-2018 #2
Get good quality bits and get your speeds / feeds right.
If you have the typical 24K RPM low torque spindle, its more difficult. Small holes are OK, large ones you will struggle.
22-05-2018 #3
22-05-2018 #4
22-05-2018 #5
22-05-2018 #6
Drill bits are not specific to CNC, however you do get lots of options which may suit a particular application far better.
Have a browse of the Phantom Drills website, and try finding a copy of their catalogue if you want to see just how many options are available.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-05-2018 #7
Why not - you're using an ER system, aren't you?
Anyway, as m_c said, there are plenty of options out there - a cursory search brought this up:
https://www.cadem.com/single-post/cn...l-helix-angles
Not a bad place to start. As per Chaz's advice - yep, it can be a bit hit and miss with the 2.2kw Chinese spindles - you don't want to go too fast and burn up the drill, but you really don't want to drop much lower than 9krpm as you risk stalling the spindle...
One thing I would say: make sure you spot drill first..! If you're using standard drill lengths then you can expect a bit of a squeal on the first peck, but that should disappear once the drill gets a bit deeper... Here's a vid of my machine drilling out a section so that I wouldn't have to deep slot (fast forward to about a minute in). I'm sure I could've gone a bit quicker, but you know - when you find something that works you tend to keep it that way..!
Good luck.
Wal.Last edited by Wal; 24-05-2018 at 08:22 AM.
23-05-2018 #8
For general purpose drilling, I'll normally get Cobalt drills. More durable than pure HSS, but typically slightly more brittle (not as brittle as pure carbide though!), and can handle higher speeds than pure HSS (but no where near as high as pure carbide).
Polished ones for aluminium, and suitably coated ones for steel.
Key thing is to ensure you are within the speeds/feeds specs for the drill, and as Chaz/Wal say, with Chinese spindles that can be a problem. You'll likely get better results on larger holes by either pre-drilling then milling to size, or just helix milling.
Spot drilling depends on what you're doing. I generally only use stub drills with split point (or whatever the manufacturer wants to call their self-centring drills), which I'll never spot drill first. However anything I need to use any longer a drill on, I'll generally spot first.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-05-2018 #9
Hello,
Drilling accurately placed holes is not easy. I strongly suggest screw length bits, the shorter the better, to eliminate deflection. I'm fairly new to cnc and posted a video of my experiences drilling holes here: https://www.youtube.com/playlist?lis...jVPFZmTCBEeF2y
I should add that I bought an old 3/8" Jacobs chuck off of ebay and a straight 1/2" shaft for it. I chucked it up in a precision collet on the router and damn if it doesn't work perfectly. For drilling operation, no more changing collets or needing collets for every different size. I highly recommend it. I show it in the video I linked to above.
Cheers, TylerLast edited by wiremonkey; 23-05-2018 at 06:30 PM.
23-05-2018 #10
I use a mix of 3mm HSS twist drill in a standard 3mm collet to pilot holes (no spot drill), and then finish on the drill press. Or interpolate holes using a 6mm end mill ideally with a spiral toolpath. Fusion is great for this.
These end up being very accurate although for bolt clearance holes I often go for bolt nominal diameter plus 0.5 mm to give some allowance in assembly.
See examples in my videos here:
4:40 and 10:40
https://www.youtube.com/watch?v=wqff3IZZWvw
Drilling Ø0.2mm holes on aluminium
By hoezap in forum Metalwork DiscussionReplies: 5Last Post: 09-04-2016, 06:28 PM -
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
RFQ: West London, Park Royal, Acton Area. 4 holes CNC drilling in my new Spindle mount & Z
By stuboy in forum Projects, Jobs & RequestsReplies: 2Last Post: 16-08-2013, 06:40 PM -
RFQ: 5 Axis Hole Drilling in Plywood - 1260 holes in 64 boards - help very much needed!
By pjm699 in forum Projects, Jobs & RequestsReplies: 3Last Post: 16-08-2012, 08:50 AM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
