View Poll Results: Which CNC Bridge is the best ?
- Voters
- 0. You may not vote on this poll
1 st design
0 0% -
2nd design
0 0% -
3th design
0 0%
10-06-2018 #11
After pippin recommendation I changed X axis design.
After changing double linear on each X axis to one linear rail, mass of bed frame and bridge are changed.
Double linear rail type : RGW35CC - 35 mm width rail - 100 mm width linear carriage block
One linear rail type : RGW45CC - 45 mm width rail - 100 mm width linear carriage block
6 linear carriage bearings canceled, 2 piece of 4m length linear rail canceled.
With the reduction of steel profiles, there is approximately total 1.500 - 2.000 USD cost reduction due to one rail design.
Old Mass :
Bridge : 1.200 kg
Bed Frame : 4.800 kg
New Mass :
Bridge : 1.100 kg
Bed Frame : 3.950 kg
I need help about X axis drive. I think both X axis and Z axis should be rack&pinion design instead of ball screw.
At X axis ball screw is way above linear rail I didnt like it, and rack&inion will get the ram closer to the saddle for Z axis.
Any ideas.
CNC Router to cut glass, marble, advice on which machine is best to buy please
By barrykavanagh365 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 05-03-2019, 08:37 AM -
Using a metal cutting burr with a router...?
By noyloj in forum Metalwork DiscussionReplies: 34Last Post: 10-01-2017, 12:44 AM -
4 axis machining software
By edgas10 in forum CAD & CAM SoftwareReplies: 14Last Post: 17-02-2016, 08:00 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
4th Axis CAM Software Multi Sided Machining
By alan2525 in forum Computer SoftwareReplies: 0Last Post: 18-02-2010, 12:44 AM
