    I want to create some core drills for a project with various grades of diamond powder and was wondering what you would recommend for attaching it to the end of the drill bit.
    I've looked at diamond brazing rods but they are as rare as rocking horse shit.
    Also thought of casting some tough RTV silicone caps with the powder in. I may have a bash at that some day.
    So the idea is to to mix in the powered diamonds to a something, then dipping the end of the tube in it and hopefully it will set hard enough not to crack off the pipe whilst machining.
    Ralph Waldo Emerson
    It's conventional to use brass tube, a dam around the work and a fluid to carry diamond for core drilling if you don't have industrially bonded diamond core drills.
    Diamond on commercial core drills is in a metal carrier because that's the only thing that won't easily fracture and break off when it's placed under cutting loads.
    I was thinking of looking into sinter-ing .. but it needs high heat. Its not a cutting load it more a grinding load. Love to know how they make diamond braising rods lol anyway it a while off just getting ideas. Thanks for the reply
    Ralph Waldo Emerson
    Quote Originally Posted by Fivetide View Post
    Like making spheres from rock with 3 cutters?
    exactly :) I have some steam pipe expanders like the hobbyists use (like me)Ill fill them will car body filler, shape them on a cricket ball then epoxy Velcro on and use cut of pieces of grinding pads to start off . it may be all I need , just exploring other ways that's all :)
    Ralph Waldo Emerson
    Diamond is heavy, in a wet environment you can separate it from almost anything else, including rock particles with a liquid cyclone.
    All you need is cups with a softer material like brass which will carry the diamond to act as a lap while it abrades the rock surface, with spiral face grooves to allow liquid flow across the surface form outside to centre and then you recycle the Diamond and some liquid to feed in to the top of the system, your Diamond is then only scrap when it becomes too fine to recover.
  1. WANTED: Powder coating, preferably cheap for a pair of sunglasses.
    By Desertboy in forum Items Wanted
    Last Post: 26-11-2018, 10:47 AM
  2. Retro fit core drill for motorised z axis suggestions
    By Fivetide in forum Other Machines & Building
    Last Post: 08-06-2018, 10:46 PM
  3. diy powder coating
    By dazza in forum Metal Finishing Techniques
    Last Post: 21-03-2013, 10:14 PM
  4. Powder coat & paint
    By craigrobbo in forum Metal Finishing Techniques
    Last Post: 06-08-2012, 09:06 PM
  5. RFQ: Recommend waterjet, metal folding, powder coating shop
    By alanambrose in forum Projects, Jobs & Requests
    Last Post: 20-02-2010, 02:14 PM
