16-06-2018 #1
I want to create some core drills for a project with various grades of diamond powder and was wondering what you would recommend for attaching it to the end of the drill bit.
I've looked at diamond brazing rods but they are as rare as rocking horse shit.
Also thought of casting some tough RTV silicone caps with the powder in. I may have a bash at that some day.
So the idea is to to mix in the powered diamonds to a something, then dipping the end of the tube in it and hopefully it will set hard enough not to crack off the pipe whilst machining.
Ralph Waldo Emerson
16-06-2018 #2
It's conventional to use brass tube, a dam around the work and a fluid to carry diamond for core drilling if you don't have industrially bonded diamond core drills.
Diamond on commercial core drills is in a metal carrier because that's the only thing that won't easily fracture and break off when it's placed under cutting loads.You think that's too expensive? You're not a Model Engineer are you? :D
17-06-2018 #3
Ralph Waldo Emerson
17-06-2018 #4
17-06-2018 #5
Ralph Waldo Emerson
17-06-2018 #6
Diamond is heavy, in a wet environment you can separate it from almost anything else, including rock particles with a liquid cyclone.
All you need is cups with a softer material like brass which will carry the diamond to act as a lap while it abrades the rock surface, with spiral face grooves to allow liquid flow across the surface form outside to centre and then you recycle the Diamond and some liquid to feed in to the top of the system, your Diamond is then only scrap when it becomes too fine to recover.You think that's too expensive? You're not a Model Engineer are you? :D
WANTED: Powder coating, preferably cheap for a pair of sunglasses.
By Desertboy in forum Items WantedReplies: 1Last Post: 26-11-2018, 10:47 AM -
Retro fit core drill for motorised z axis suggestions
By Fivetide in forum Other Machines & BuildingReplies: 4Last Post: 08-06-2018, 10:46 PM -
diy powder coating
By dazza in forum Metal Finishing TechniquesReplies: 8Last Post: 21-03-2013, 10:14 PM -
Powder coat & paint
By craigrobbo in forum Metal Finishing TechniquesReplies: 6Last Post: 06-08-2012, 09:06 PM -
RFQ: Recommend waterjet, metal folding, powder coating shop
By alanambrose in forum Projects, Jobs & RequestsReplies: 6Last Post: 20-02-2010, 02:14 PM
