    Hi.
    I am not sure if this is the right bit of the forum for this question but here goes anyhow.
    I have acquired this pump. Pictures below.
    Apparently they are used in the air conditioning industry for replenishing fluids or something. My friend had it as a backup for his vacuum pot but no longer needs it. He does woodturning stuff and uses a vacuum pot to impregnate epoxy into wood to stabilise it before turning it. He uses a very similar but slightly smaller pump.
    My question is would this be suitable for use with a vacuum bed/ chuck for work holding on my cnc (once its operational)?
    Thinking of this sort of thing. But I will probably try some HDPE because I have some.
    If not I might be able to use it as a bagpress type thing. It looks similar to their smaller pumps.
    Ollie
    Lives in East Lothian, United Kingdom. Last Activity: 48 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    It should work for smaller tables, but you can't run coolant unless you install a filter/tank to catch any stray coolant before it gets to the pump, and you'll also need a good dust/swarf filter. Coolant and dust/swarf will quickly contaminate the pump oil.
    Thanks m_c
    I am mainly intending to machine wood so coolant should not be an issue. I will add a filter somewhere in the airline for the dust, I had not considered that before.
    My worry was will it be able to run for longer jobs without overheating or something ?
ID:	24409As per MC
    should be fine with small surface area, also more than adequate for vacuum bagging. Have run mine for hours without a problem BUT you will get oil vapour from the exhaust and you need to vent this out of the workshop.
    Regards
    Mike
  1. Vacuum Pump Station
    By Boyan Silyavski in forum Metalwork Project Showcase
    Last Post: 14-01-2016, 11:05 AM
  2. Vacuum pump wiring
    By Danielroyal25 in forum General Electronics
    Last Post: 01-01-2016, 12:51 AM
  3. Vacuum pump for a large matrix bed cnc 5 by 10 foot
    By gavztheouch in forum General Electronics
    Last Post: 03-11-2013, 06:01 PM
  4. SAE thread fittings Vacuum Pump
    By Bazzer in forum Marketplace Discussion
    Last Post: 27-05-2013, 12:02 AM
  5. FOR SALE: 10 litre Vacuum degasser chamber with Robinair pump
    By Fivetide in forum Items For Sale
    Last Post: 13-02-2013, 06:21 PM
