15-06-2018 #2
I can not see any thing wrong with how the stepper driver is set up
with stepper motors the motor current depends on what you set by the DIP switches - sw1 to sw3
not the mechanical load on the motor
so the current does not go up when you mechanically load the motor as you may of expected
depending on which manufactures data sheet you look at
the motor can safely run at 70 to 80 degrees C - too hot to touch !
a quick look on line did not find clear instructions for the setting of sw4
but going by a photo of your DQ860MA driver
I expect sw4 sets the current reduction when the switch is set to OFF and the motor is idle ( not being stepped )
set to ON the motor will run hotter but should be OK
setting the motor current to 4.9A instead of 5.6A will do two things
1) reduce the motors temperature
2) reduce the motor torque
if the room temperature is not too high
then I expect you can safely set the motor current to 5.7A
the extra 1.7% current should not be a problem
especially with sw4 OFF
JohnLast edited by john swift; 15-06-2018 at 10:54 PM.
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
