Thread: choosing a bleed resistor
11-07-2018 #21
looking at PCB art work
http://electronics-diy.com/soft-star...wer-supply.php
it looks like its a project take from the Dutch: Elektuur magazine
John
PS
found it
the delay is from the July August 1997 issue of Elektor
the B250C1500 is a 1.5A 500V bridge rectifier
I would of thought a 1A bridge rectifier would be OK
or four 1N4007 diodesLast edited by john swift; 11-07-2018 at 04:09 PM. Reason: add ref to July August 1997 issue
Hi John.
Thanks very much, saved me some time this evening hunting for the article.
Andrew
11-07-2018 #23
Or use a NTC thermistor.
BTW, that design - the resistor wattage values are wrong - if, as claimed, it's intended to limit the current to 5A then the resistors should be rated at 250W (P=I^2 x R). I'd also caution that C1 is specified at the limits of its operation - failure of that would result in the explosive failure of C2 C2 and likely destruction of R1 and RE1.
Treat with care.
Oh, you dissipate about 6W in that capacitor and relay.
And A-Camera, electric shock isn't the only hazard of a charged capacitor. The biggest hazard at this potential are burns and physical injury resulting from a spontaneous reaction to a sudden discharge. You mention batteries - of course you don't use a bleed resistor on batteries - that's a divisive argument. But the first instruction in any vehicle maintenance manual is to remove the -V lead before any work. Why?Last edited by Doddy; 11-07-2018 at 07:21 PM. Reason: Why do I let myself get wound up
11-07-2018 #24
Why build a second power supply just to run the relay? How about driving a 24V relay from the existing power supply output via a suitable zener? With a zener chosen to drop enough volts to give nominal relay voltage when PSU is at working voltage, the relay will operate a little earlier than that, but by then the initial surge will be over. Even simpler, use a series resistor to give nominal relay voltage at PSU nominal output. I'm not convinced that surge protection is needed at all (my system works fine without but I chose my input MCB carefully so nothing trips, and that's the only reason why you need to bother) but if it is, make it as simple as possible. I've never used the NTC approach, partly because it looks as if you have to choose carefully to match PSU current draw, which is pretty variable driving a CNC machine.
11-07-2018 #25
I would like to know what the design input voltage is to this soft tart circuit in Elektuur. We are assuming 50v as that is what we need, but it has 40v caps and a 24v relay.
11-07-2018 #26
Nope, it's 220-240 on the primary of the toroidal, something that should be borne in mind for our US readers.
It uses a potential divider across the C1 capacitor and the relay coil. It works as-is, but is fraught with problems when people start substituting components.Last edited by Doddy; 11-07-2018 at 07:49 PM.
11-07-2018 #27
Sorry Doddy, I was trying to delete my post as I realised it was mains input. Just had a senior moment !
11-07-2018 #28
11-07-2018 #29
Hi A_Camera,
What did i say wrong to make you throw up that many words?
I am not here to challenge anyone's knowledge, or but heads.
The mentioned purpose of the bleed resistor is getting rid of the charge ... at some point ... after shutting down.
Limiting in rush current is a good idea to keep cb in turned on position at power up.
Now for the playing down of electrical dangers.
Uncontrolled / unintential discharge of capacitors can lead to damage and can potentially hurt you in the process.. at any voltage.
If you look at those videos you must have been able to spot that.
Higher voltage levels have higher potential to disrupt hart rhythm AC or DC , when it makes current flow through the body and meets the hart along its route.
Being in close contact with well grounded metal surfaces clearly does not help to make it more safe.
Higher amp rates burn stuff like metal and can vaporize it.
Heat burns the skin last time i checked.
So what i would like you to do is not under estimate and be mature about dangers of electricity.
So from my point of view clearly YOU don't understand.
But there is of course, potentially, the Darwin award for anyone who does not work and or design in a safe way.
My 2cents worth.
Grts Bert.
need help! choosing right kit
By msacnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 17-09-2014, 09:41 AM -
Resistor Question
By GTJim in forum General ElectronicsReplies: 1Last Post: 07-04-2013, 10:01 AM -
Resistor Calculator
By Lee Roberts in forum General ElectronicsReplies: 2Last Post: 17-04-2012, 05:22 AM -
ATX power supply - load resistor - do I need one ?
By rckeith in forum General ElectronicsReplies: 4Last Post: 18-08-2010, 03:21 PM -
What type of resistor?
By Smiler in forum General ElectronicsReplies: 4Last Post: 05-12-2008, 10:04 PM
