Thread: Setting up new spindle
22-07-2018 #1
I have just wired up my spindle. The spindle is running very hot and I get a error after a few minutes on the enerror is E0H5 and E0HA. Now the settings have pd008 at 220 and the spindle label says 080#200 2.2kw 110V. 8.5A 400hz. It’s water cooled. The inverter is a Huanyang hy02d211b. 3phac110+-20% 50hz+-5hz in. 3 ph 0-110ac 2.2kw 20A .50-400hz out.
This is running in the US 110V 60hz. So should pd008 be set at 110. Plus pd173 is at 255.
Is there a problem that the inverter is for 50+-5 hz running on US current.
25-07-2018 #2
PD008 should be set to 110.
There's a good chance you've already damaged either the spindle or VFD, or both.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
25-07-2018 #3
Changed settings and everything is working fine.
10-12-2019 #4
Hi, I also need the settings for a 110v HY vfd with 2.2 kw, 110v spindle, 8.5 amp. I think I have most correct but I am unsure about PD006, PD007, PD009 , PD010 and PD041.
Thanks, Joe
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Setting my table up...
By Davek0974 in forum Plasma Table MachinesReplies: 23Last Post: 10-03-2014, 08:24 PM -
setting up a business
By dstivens in forum Opportunities Available & SoughtReplies: 5Last Post: 16-05-2013, 10:28 PM -
setting the origin
By Fivetide in forum Computer SoftwareReplies: 9Last Post: 04-02-2013, 12:18 AM -
setting up Moeller VFD to chinese spindle
By routercnc in forum Spindles & Drive MotorsReplies: 16Last Post: 16-02-2011, 08:22 PM
