    Hi guys, I searched the forum but couldn't find if it had been answered.
    As I am really limited on space and trying to maximise the surface area as best as I can
    I am debating the following for a machine 1100 x 800mm approx:
    1) 60x60x4mm steel box with motors on outside + as bulk buying steel gantry would be also made of 60x60x4 and 180mm in height
    2) 80x80x3mm steel with motors inside + as bulk buying steel gantry would be made also of 80x80x3 and 160mm or possiblely 240mm in height
    Any possible pros or cons ?
    Any advice is appreciated
    Mike
    Hi Mike
    It has been asked before over the years but I can’t honestly remember seeing a finished machine with that feature so it is difficult to say if it will get hot. Maybe someone else has.
    The mounting face of the stepper will be bolted to a metal plate which will dissipate some heat.
    To help the main body stay cool you could drill a large hole in the top and bottom surface of the section biased towards the rear end of the stepper to promote an updraft.
    The motors run warm / slightly hot to the touch if they are being worked but that is in the open. Not trying to scare you but there is a temperature over which the stepper magnets break down. From memory I think it is 150deg? But if it is inside the box you won’t know.
    So for small jobs I think it would be OK ( don’t hold me to it!) but an 8 hour run . . .
    Many thanks routercnc.. heat was something I had not even considered.
    Mike
    as the motor current is set by the stepper driver and does not change with the mechanical load
    from various data sheets I have looked at motors are designed normally run at 70 C to 80 C
    I would expect the motor to heat up to a maximum value in the first hour or two assuming there is no current reduction when the axis is idle
    In the confined space inside a 80mm square tube
    with only a 7 or 8 mm gap around the motor
    I would consider using a fan to force air past the motor
    how are you going to mount the motor inside of the tube so you can adjust its alignment with the ball screw ?
    John
    PS
    I have no idea of how much effect it will have but
    having the motor enclosed in a metal tube could change the amount of heating of the motor due to changes in the eddy currents in the motor and possibly eddy current heating of the tube
    The risk of the motors overheating and the actual time and effort I would need to make it so I would be happy with the build is not worth it - many thanks guys - I think there is a reason its not been done before ..
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Hulksmash View Post
    I see you are Salford If you want to see my machine you are welcome I am in Marple Nr. Stockport It might give you some ideas. It is 1600x1000 overall size.
    Thanks alot Clive thats really appreciated. I actually live in a place called astley but no-one has ever heard of it so its easier to put the closest place...salford.
    I will definatley arrange to visit once I'm sorted. Your a really handy person to have close 😁
    Clive S's Avatar
    If I remember there used to be a good Chinese there not too far from the church PM me if you want to pop over.
    You thinking of the Tung Fong in Worsley... the outside looks Tudor looking... white and black.
    Clive S's Avatar
    Yes that's the one.
  1. Replies: 1
    Last Post: 07-05-2017, 02:30 PM
  2. Water-cooled spindle tubing
    By d4cnc in forum General Discussion
    Last Post: 23-04-2016, 11:16 AM
  3. editing files inside solidworks
    By reefy86 in forum Solidworks
    Last Post: 17-02-2016, 12:20 AM
  4. Aluminium tubing for telescopic support
    By irving2008 in forum Marketplace Discussion
    Last Post: 12-09-2013, 06:19 AM
  5. FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
    By Shinobiwan in forum Items For Sale
    Last Post: 02-02-2013, 10:54 AM
