Thread: Advice for cutting acrylic sheet
09-08-2018 #11
Chloroform dissolves acryllic for that perfect glue line. Everything else is but a poor sustitute.
09-08-2018 #12
https://uk.rs-online.com/web/p/produ...E&gclsrc=aw.ds
Methylene chloride can also be used to bond the stuff, but it will mar the surface if you use too much.Last edited by cropwell; 09-08-2018 at 11:38 AM.
09-08-2018 #13
Chloroform is trichloromethane.
09-08-2018 #14
09-08-2018 #15
...and a cheap cigar is still a smoke!
09-08-2018 #16
09-08-2018 #17
10-08-2018 #18
One fixing method I use for thin wood and acrylic is to firmly clamp the blank down as normal to a sacrificial base and start the cutting with a stand-alone drilling operation to create fixing holes between the parts to be cut. Where possible I also cut holes that are part of the pieces at this point. Fixing screws can then be used at many places within the sheet, not just clamps at the edges. The clamps can them be removed to allow cutting out to the edges of the piece if required.
Depending on what holes are part of the piece to be cut and what extra holes you can tolerate adding, this method can be used to avoid the need for holding tabs.
This works well but needs to be planned carefully and the fixing holes are best drawn on their own layer as part of the overall layout design.Last edited by Kitwn; 11-08-2018 at 12:01 AM.
Advice for cutting sheet aluminium
By Drucook in forum Metalwork DiscussionReplies: 6Last Post: 13-06-2018, 03:19 PM -
Which cutting tool on acrylic?
By piper1 in forum Machine DiscussionReplies: 7Last Post: 06-07-2017, 11:12 PM -
CNC cutting service (acrylic/perspex, mdf, plywood, carbon etc)
By adrpak in forum Manufacturer NewsReplies: 0Last Post: 28-04-2017, 06:38 AM -
Acrylic Cutting Help
By Tenson in forum Machine DiscussionReplies: 26Last Post: 08-11-2016, 08:15 PM -
Laser cutting 10mm acrylic?
By camhguh in forum Laser Machines & BuildingReplies: 14Last Post: 04-09-2012, 12:51 AM
