    Thinking of getting one of these for a spindle project:
    https://www.aliexpress.com/item/130S...355475440.html
    Want to interface it into mach3 in speed/torque control mode for on/off & speed 0-10v. Also for e-stop to trigger mach if motor jams/stops if poss.
    Anyone used one before?
    I can only find Chinese wiring instructions around and wouldn't have a clue which pins to use on the DB25 interface. Or if it can work with mach. Anyone here in the know?
    There is already a relay and 0-10v out on my BOB ready to use. And could tie it into my existing e-stop circuit.
    Would rather know before I throw money at it.
    Daz.
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    If you've not got a English copy of the manual yet, PM your email and I can send you a copy.
    By the sounds of it, you'll want to run 0-10V Speed control mode.
    I'm not sure if a standard fault output will work for if the motor stalls, so you may have to try something like an At Speed output option.
    Other option would be to run the motor using step/dir, then use an On/At Position output option.
    ive got a few of these on my mill, all connected to mach3; been very impressed.
  1. Replies: 0
    Last Post: 02-01-2018, 10:56 AM
  2. Lenze 8200 VFD Inverter - Spindle motor not moving
    By Fgc in forum Spindles & Drive Motors
    Last Post: 13-11-2017, 02:34 AM
  3. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
  4. Replies: 2
  5. Dilemma with ball screw and motor mounting
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 12-08-2011, 10:58 AM
