Thread: Problem with Millpwr...
24-09-2009 #1
Bit of a long shot as I don't think theres many of these systems around...
We have a Bridgeport fitted with an Acurite Millpwr CNC system, [which I have to say is a great conversational CNC control for simple machining op's]. Recently however, we have been experiencing a few problems. It is giving a number of error messages, the most common of which is that the gaurd is open.. when it isn't... checked the wiring to the guards it's all ok, even tried wiring it out but still get the error message. There are other errors, such as low on lube oil, and it will start and stop the spindle on it's own occasionally with the direction switch in the off position, when the machine isn't even set up.... which scared the &^%$ out of me one evening when I was working at the bench all on my own!! Another frequent message is 'AMI output fault' when in program mode....
Any thoughts??? could it be a software issue perhaps??? Anybody else running one of these???
Grah.
24-09-2009 #2
I don't know anything specifically about the Accurite system but...
First thing to check on any system like this is plugs and sockets - take them apart at inspect closely for corrosion (especially if they are exposed to coolant spray) remove the covers and check the wires inside the plugs (same goes for switches).
If any of the cables are flexed by the movement of the machine, consider replacing them (the conductor wire work hardens and breaks in different places, often causing intermittent faults).
If the wires and plugs seem OK, then check power supplies and earth connections.
28-09-2009 #3
Thanks for the pointer Bill.
It looks very much like it might have been the AMI socket on the processor input/output board. I've replaced it with some nifty soldering and, so far, things seem to be ok. The little pin sockets on the old one were all shapes and possibly therefore not making contact as well as they should.
28-09-2009 #4
:cry: ..... perhaps not.... just had the problems again!!
Time to get the man in I guess...
05-10-2009 #5
... not had a lot of success with getting the man in... don't seem that interested!! [Business must be good!!??]
We have found that a couple of components are running hot on the AMI board in the back cabinet. We have a replacement 5v voltage reg, but the resistor next to it has got so hot it's lost it's colours... If anybody has a similar machine and can have a quick look in the back cabinet and let us know what it should be we would be very very grateful!!
Grah.
02-11-2009 #6
were running this control too, v3.4
If you still need to find out the resistance colour code i'll have a look and post back tomorrow!
02-11-2009 #7
Hi
We measured the resistance and just replaced it with something similar which seems to work ok. If you get chance to check the proper colours it may be useful to know in case it occurs again tho'... thanks!
G.
Powertran VFD problem
By phill05 in forum Spindles & Drive MotorsReplies: 7Last Post: 29-10-2013, 07:59 PM -
Bearing fit problem
By paulus.v in forum Linear & Rotary MotionReplies: 7Last Post: 09-10-2013, 09:54 AM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
