I have a two parts I would like to get a price for being machined in ali.
It is basically design to be machined from a 30mm square bar total length is 605mm. It is the same on 3 out of the 4 sides with exception to the extra square holes and screw holes on the last side.
The second part is just a block that is press fit snugly into the hole with a bolt hole down the center to secure.
I would guess doing it on a 4 axis setup would be the easiest but would think any solid 3 axis should be capable. If anyone can help please drop me a message and I can send the files. many thanks
