    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Does anybody know how the washers are arranged in the power draw bar. For the Novamill
    not sure about the novamill but all the other machines I have replaced them on have had 3 with dome up, 3 with dome down etc
    I'm sure they're just one each way.
    Just found the parts diagram, and it's 27 washers, mounted alternating ways, with the bottom one sitting cone up/it's wide face against the bottom of the housing.
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #4
    Thanks. I thought you would know. I have 30 coming in the post. Then I can test it out.
    edit: Also If I remember I put a 4mm thread in the bottom of the draw bar I presume this is to be adjusted for different length of pull studs. Is the adjustment in the manual?
  6. #5
    Ok Belleville washers fitted. Quick vid + pic. https://photos.app.goo.gl/KvMPgAApyS87yns56 Just have to clean it up now.
    Do you have the correct torque settings for the stack of washers. Come to think of it I might have put a finer thread on the draw bar
  7. #6
    There's nothing in the manual about adjustment that I can remember. Probably worth having a search over on the Denford forum, or even asking.
    I'd guess it'll be a case of adjusting the stack up until the tool doesn't release, then back it of a bit. It's not like you need a huge amount of retention power given the spindle motor fitted to a Novamill.
  8. #7
    Thanks, I will do a bit more research
  1. FOR SALE: Denford Novamill
    By Paul Urquhart in forum Items For Sale
    Last Post: 21-01-2019, 11:48 AM
  2. FOR SALE: Denford Novamill
    By m_c in forum Items For Sale
    Last Post: 27-01-2017, 04:41 PM
  3. FOR SALE: Denford Novamill for sale
    By Clive S in forum Items For Sale
    Last Post: 27-01-2017, 12:48 PM
  4. FOR SALE: 2 x Denford Novamill cnc machines + table.
    By Spaniel84 in forum Items For Sale
    Last Post: 21-09-2016, 11:54 AM
  5. FOR SALE: for sale: Denford Novamill
    By Mash Govan in forum Items For Sale
    Last Post: 12-04-2016, 11:18 AM
