Page 2 of 2 FirstFirst 12
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Hows things going with these screws? Had any luck?
    If you're still looking for oil/grease recommendations, Lee gave me a great reply recently - the short version being lithium based grease - if you look at the HIWIN greasing guide, you'll also see EP1 mentioned.
    http://www.mycncuk.com/threads/11552...y?goto=newpost
    Yes, Fred has been good to his word and sorted me out with some replacement bits including completely replacing the 1204 screws which had the slightly wonky end machining - you can't fault the guy's service, 10/10. Regarding the grease, looking at the specs Hiwin recommend, I've realised that I already have something that should do - Mobil 1, which I bought for re-packing the struts on the car.
    Whilst pondering ways to make a linear motion assembly thinner I pulled out one of these old ballscrews to look at, I'm the kind of guy that thinks much better with something physical in my hands. Whilst idly twiddling it and looking down the end of the nut I noticed there was a definite gap in the line of balls if you held it horizontally and rotated the screw, you could hear the balls tipping over the crown of the screw as they made their way down the other side, sometimes accompanied by a sudden roughness is the rotation force. If you held the screw upright this didn't seem to happen, presumably gravity was sorting things out. This made me think, shouldn't there be a more or less continual line of balls??? could this be why they still felt rough after quite a bit of cleaning out of swarf?? Any advice from linear motion experts would be very welcome.
  1. machining ballscrews
    By T0rnado69 in forum Lead Screws, Nuts & Supports
    Last Post: 13-04-2014, 11:39 PM
  2. Best place to get ballscrews?
    By Ross77 in forum Lead Screws, Nuts & Supports
    Last Post: 15-04-2013, 10:09 PM
  3. machined ballscrews
    By wilfy in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2012, 05:42 PM
  4. Two ballscrews on both X and Y axis?
    By Jonathan in forum Gantry/Router Machines & Building
    Last Post: 02-02-2012, 01:55 AM
  5. supports for ballscrews
    By leadinglights in forum Lead Screws, Nuts & Supports
    Last Post: 27-04-2010, 12:31 PM
