    Hi, as will become apparent I am new to all of this.
    I have aquired a Denford MicroRouter that has been modified to run on Mach3 using what I believe is the original Cable Porter spindle. What I want to do is fit a new spindle with an ER collet so I can use smal (1.0 dia) cutters to finish components that have been semi-finished on a different machine. As I would still like to use the router for machining wood I would ideally like to find a spindle that will run off the existing electronics.
    The on/off and speed of the spindle fitted is controlled by a Spindle V5 board (https://0201.nccdn.net/4_2/000/000/0...spindleV5x.pdf). I have attached pictures of all the other internals in case information on them is needed.
    Any help/advice greatly appreciated.
    buy a 6mm collet for the current porter cable spindle
    then buy a 1mm cutter with a 6mm shank (ebay)
    job done, very easy, save loads of money and time
    Quote Originally Posted by ngwagwa View Post
    Quote Originally Posted by andy_con View Post
    If you can get a 1/8" collet, then there is a whole world of cheap cutters out there.
    Hi, as well as the Porter cable being an open motor I was also worried about the run out. I am will be using some long reach ball neck tools so need to get down to a 3mm fillet.
    if your concerned about accuracy then a £500 route probably isn't the best for the job.
    Accuracy of the part isn't critical, the long reach tools are the only way I can cut the required profiles.
    it seems a huge amount of work, for very little gain. but I suppose if its the only way to make the part then there is no other option.
    id also be very surprised if you could find a suitable spindle that is a straight swap.
    I didn't expect to be able to do a straight swap (though it would be nice). Would I be better looking at a new spindle and building a new control box for it? It would certainly make swapping between spindles easier/
    The BoB you have, I am certain, has 0-10v output to control spindle speed with a VFD and Spindle setup, so you don't need any more electronics apart from the VFD. The rest is setting it up in Mach3.
    Thanks, so which spindle should I be looking at bearing in mind it is for finishing only so RPM is more important than power.
  1. Help required with mill conversion / upgrade.
    By swarf-boy in forum Milling Machines, Builds & Conversions
    Last Post: 06-12-2018, 12:33 PM
  2. Upgrade to x axis required. MG or HG rail
    By marbles in forum Rails, Guideways & Bearings
    Last Post: 10-12-2017, 01:51 PM
  3. Roland camm 2 pnc 2300 spindle upgrade help
    By iampete in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 03:17 PM
  4. Kress Spindle upgrade to a 2kw
    By Metal pecker in forum Kress Milling Motors
    Last Post: 05-05-2014, 12:22 PM
  5. advice on upgrade to 5 axis control
    By alanb in forum General Electronics
    Last Post: 27-07-2012, 06:29 AM
