05-04-2019 #11
you may need a new psu to meet the spec of the new spindle
The Following User Says Thank You to andy_con For This Useful Post:
05-04-2019 #12
The Following User Says Thank You to cropwell For This Useful Post:
05-04-2019 #13
I probably can't afford quality so would settle for Chinese.
The Following User Says Thank You to ngwagwa For This Useful Post:
06-04-2019 #14
Have you seen this? https://www.youtube.com/watch?v=jfryQr10nbo - someone has added a 1.5kW spindle to a micro router.
The Following User Says Thank You to Doddy For This Useful Post:
06-04-2019 #15
Thanks for that it's ust what I am aiming at.
26-04-2019 #16
Just a quick update to let you all know the outcome.
I ended up buying a serial to RS-485 adapter (less than £3 on fleabay) and downloaded a plugin to ebable Mach3 to control my spindle directly.
The new spindle is fitted and running and I was originally using a 5 gallon drum for a water reservoir but this didn't stop the temperature hitting the mid forties centigrade during the hot Easter weekend. I have to point out my workshop is upstairs and the room temperature was in the low thirties. As downstairs is always a lot cooler and having plenty of plastic pipe to hand I simply added about 15 metres of pipe to the outet and ran this downstairs then bak to the tank which solved the cooling problem.
26-05-2019 #17
Finally have the time to cut a job for which the spindle was purchased.
Help required with mill conversion / upgrade.
By swarf-boy in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 06-12-2018, 12:33 PM -
Upgrade to x axis required. MG or HG rail
By marbles in forum Rails, Guideways & BearingsReplies: 0Last Post: 10-12-2017, 01:51 PM -
Roland camm 2 pnc 2300 spindle upgrade help
By iampete in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-09-2014, 03:17 PM -
Kress Spindle upgrade to a 2kw
By Metal pecker in forum Kress Milling MotorsReplies: 4Last Post: 05-05-2014, 12:22 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
