30-04-2019 #4
There is a reason I picked which questions to answer and which to avoid!
Washout makes a good point about the adjustment of things. I like your ballscrew placement idea on the gantry, but it doesn't leave a lot of room for height errors - the location of the top plate will be defined by the carriages, which may or may not co-inside with the height of your ballnut support. You may want to design with say, a 5mm shim under the BK/BF12, so that you can adjust the shims to get the right height. This is why the ballscrew on mine is on the back of the L shape, it allows me to adjust for height relative to the carriages - but leads to a slightly more flimsy 3-sides of a box shape.Last edited by AndyUK; 30-04-2019 at 01:30 PM.
The Following User Says Thank You to AndyUK For This Useful Post:
BUILD LOG: Desktop build with zero budget. Critique my design please?
By Nealieboyee in forum DIY Router Build LogsReplies: 16Last Post: 25-07-2017, 03:50 PM -
NEW TO CNC - Starting design and so forth
By PSG in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 19-03-2014, 10:30 AM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
