Thread: Gantry advice please
Hi
I have introduced my self in the new comers section ,
I have a few question to ask.
I had planned to use box steel for gantry,
Cut a letter box in the front so I could put ball screw inside.
The box is 200 x 100 x 8 not the one shown in photo.
I wanted to make this as rigid as possible as I want to be able to cut aluminium.
What is an acceptable weight of a gantry with every thing on it including spindle, it terms of performance, I understand the heavier it gets the more effort it takes to start and stop it when moving due to the mass. Do you just deal with the extra weight with gearing or bigger steppers? Or is there a sweet spot in weight ?
Also which ball screws would be best to use,
2 x 900mm 1605 or 1610 with pulleys y axis. ( front to back ) or
2 x 900mm 2005 or 2010 with pulleys y axis. ( front to back ) would you get whip on this length and would these be better with a heavier gantry?
1 x 1200mm 2005 or 2010 with pulleys on x axis ( left to right ) again for whip due to length .
I have planned dual steppers for y axis .
Any advice would be great .
Regards Paul
Sent from my SM-G900F using TapatalkLast edited by Crunch; 02-05-2019 at 05:07 PM.
03-05-2019 #2
Hey, you've got some tidy welding there! If you look here:
http://www.mycncuk.com/threads/1524-...per+motor+size
there's a very useful spreadsheet that enables you to play with and optimise weight/ballscrews/motor size. I'm not quite sure what you mean by cutting a letterbox in your gantry box, but do remember that the torsional rigidity of a box section will be significantly reduced if you start cutting longitudinal slots in it, it will become more a like a C-section/channel.Last edited by Voicecoil; 03-05-2019 at 10:04 AM.
The Following User Says Thank You to Voicecoil For This Useful Post:
03-05-2019 #3
Thank you
I'll have a look later .
03-05-2019 #4
Don't cut the tube. Add diagonal braces and end caps (welded, glued, or bolted).
Don't worry about weight. My dual drive 381 Oz in steppers will throw around my 100kg gantry system at 20metres/min.Last edited by pippin88; 03-05-2019 at 12:11 PM.
03-05-2019 #5
03-05-2019 #6
If it helps while you wait for the time difference my gantry must be close to 100kg as it is double beam with lots of thick aluminium plates on Y and Z, double screws etc. I have 2 ballscrews driving it at 1605 size and pitch with no issues but would happily go to 1610 if I did another one to get the speeds up for wood. Then swap pulley out to 2:1 for aluminium if required. They are just over 1000 mm and no whip issues.
Each screw is driven by a 3Nm stepper of about 3mH inductance at around 70V. A very strong set up. I’m running legacy (old!) analogue stepper drivers but for a new build go digital.
If you are yet to order the screws and want to go belt drive then make sure you ask for enough machined length on the end to get the pulley on as the standard offerings can be a bit short. Check the drawings they provide against how you will use them to be sure.
Your other question about the 1200 mm ballscrew on Y - this is getting long for screws but I would say still doable. I’ve not built anything with screws that long but my thoughts would be stay with 1610 to avoid having too much inertia and provision for another ballscrew support at the floating end to add some pre- tension. Also I’d think about adding 2 ballnuts on the Y axis unit spaced as far apart as the Y/Z axis allows to hold the ballscrew in 2 places and give slightly less free length when the Y axis is off to one side.
If someone has direct experience of 1200 mm screws then let that be your decider as the above are just my thoughts based build quite a few slightly smaller machines.
As for the letterbox idea it is tempting but as has been mentioned you will loose a lot of stiffness. Mount the screw somewhere on the outside even if you have to space that axis away from the gantry a bit.
Looking great so far by the way (and welcome to the site)Last edited by routercnc; 03-05-2019 at 07:11 PM.
03-05-2019 #7
Thank you for your welcome to the site.
Thank you for the information that's a great help.
I was mainly wanting to fit ball screw inside gantry to save space and keep it compact. Based on comments not a good idea as it will weaken it to much .
I even thought of welding a round tube inside the gantry for the ball screw to run in, still cut the front out and weld it all up so it braced the open parts together.
I don't know if that makes sence. Lol
Also dont know how much that would weaken it.
I will think on how to mount it on the out side.
Thanks for advice on ball screw length , I've been talking with Fred from bst ( I think that's what his company is called )
He has been very good. I've not ordered linear rails yet as I want to order ball screws at the same time but not sure what to order hence questions.
I'm not ordering any electrics until mechanicals are finished.
What do you think to closed loop steppers vs open steppers.
Regards Paul
Sent from my SM-G900F using TapatalkLast edited by Crunch; 03-05-2019 at 07:53 PM.
03-05-2019 #8
04-05-2019 #9
Gantry span 1300mm.
15mm pitch screws. 15mm diameter I think. They are secondhand ground screws.
I use 16mm pitch 16mm diameter screws on other axes (from BST automation).
No pulleys.
Steppers are best used with high pitch screws (10mm or more) not 5mm pitch screws. Steppers have max torque at 0rpm and it falls as rpm rise.
Servos are different. They are rated for torque at rated rpm (often 3000rpm).Last edited by pippin88; 04-05-2019 at 01:09 AM.
03-06-2019 #10
Pippin88,
How do you get 20m/min out of those motors direct-driving your screws? Is it something to do with the quality of screws you're using?
I can only get 7m/min direct-driving 1530mm of 2010 which (I thought) agreed with the theoretical max speed of the calculations I did.
On a 16mm pitch that same calculation says I could maybe get 12144mm/min on the same motors but that still seems way off what you're managing (and my gantry is light - made-from-plywood-light!).
MatthewLast edited by mattnedgus; 03-06-2019 at 11:09 PM.
Need advice on gantry design
By jcarpenter in forum Gantry/Router Machines & BuildingReplies: 33Last Post: 13-05-2018, 01:51 PM -
Advice and opinions 3 axis gantry for cutting Ply / Hardwoods
By Jeff in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 09-10-2017, 04:38 PM -
Physicist trying to do engineering. Not going well. After advice with 4 axis gantry.
By dr_rob in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 07-12-2016, 11:34 PM -
Fixed Gantry small precision begineer project advice
By yasu in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 17-10-2016, 07:14 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM
