    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,553. Received thanks 167 times, giving thanks to others 656 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Hey “yall”
    I’m looking at limit switches for my new machine, has anyone used Proximity Sensor’s on their machine and is there a brand that would better for this job.
    Also would the door sensors you find on house alarms be any good/reliable for this kind of thing?
    Thanks,
    .Me
    Hey “yall”
    Thanks,
    Bad Juju.
    prox sensors not accurate/repeatable enough (at a price you can afford) and get a speck of swarf, wood chips etc etc on the target and you lose any accuracy . Why you swimming against the stream man? Go with the flow, go mechanical, tried and true tech. Or optical if you like although they suffer similar problems to proximities.
    You just trying to be different Mr. Lee?
    Jeff.
    I'm going magnetic with my limit switches. Home switches won't be repeatable (haven't decided what to do with them), but since limit switches are, for me, just in case of emergencies, it would be fine.
    Plus I'm not cutting metals, so not too worried about swarf.
    As a related aside, I do some electronics for a crop spraying company. My electronics controls a 4-wheel steering system, where it switches between 2-wheel and 4-wheel steering. When switching from 4 to 2, it can only do this when the front wheels are aligned. They use magnetic sensors for that with a thin plate bolted on to the steering rack. The magnetic sensor picks up the edge of the thin plate, and is accurate to about 2mm.
    Hi
    we use inductive sensors from Wenglor or Baluff, seem to work fine.
    mike
    www.techservcnc.com
  5. Don't confuse limit switches, which are for emergencies, with home switches which need to be accurate and repeatable. Personaly I'd stick with mechanical switches since it is much easier to make these fail-safe compared to purely electronic ones.
    Exactly my point. Put much more succinctly than I ever could.
    And as Mach (which I use) can use them as both it IS important they are accurate, repeatable and reliable.
    So there.
  1. Proximity limit switch problems
    By davrich in forum General Electronics
    Last Post: 12-03-2018, 12:58 PM
  2. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC/EMC
    Last Post: 15-10-2014, 08:51 AM
  3. Proximity Switches
    By kingcreaky in forum General Electronics
    Last Post: 23-10-2013, 12:30 PM
  4. Limit Switches
    By Leadhead in forum General Electronics
    Last Post: 16-10-2013, 09:41 AM
  5. Proximity Sensors / Mach3 not showing
    By dudz in forum General Electronics
    Last Post: 15-06-2013, 07:47 AM
