Given the same the same stepover and stepdown. Would it be preferable to use for instance an 8mm bullnose or a 4mm bullnose when cutting EPS foam. I believe the finish may be better with the larger dia. but would the smaller dia. be better for the grain structure?? I know not to climb cut but otherwise, not much experience of this material.
Any advise appreciated.
