Page 2 of 2 FirstFirst 12
    This is why you want to screen all the cables and ground them to a single point at the control box/VFD end.
    For emissive cables (steppers, spindle) you should bond the screen at both ends to the respective enclosures.
    <Opens popcorn>
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 4 Hours Ago Has been a member for 6-7 years. Has a total post count of 417. Received thanks 61 times, giving thanks to others 10 times.
    Haha, nice try. Some (most) VFD manufacturers say one end, others say both ends. Probably doesn't really matter for the sort of work we do but this is an old chestnut. Let's just say there is no right or wrong here...
    Quote Originally Posted by Paul53 View Post
    none of you live in Hampshire by any chance?
    Sorry no, I live in Exmouth. The one in Western Australia. I'm not sure my advice is worth a cup of tea anyway.
    Earthing everything to a single point is supposed to prevent earth loops, the cause of much mains hum in audio equipment. This is probably the thinking behind only connecting screens at one end. As you'd be earthing the body of your machine back to the same point with fairly short wiring anyway it probably doesn't matter. Belt and braces is to make the cable so you CAN connect at both ends but be able to disconnect if you have problems.
    On a safety note: The output of your VFD is at potentially lethal voltages and is isolated from the mains input so you get no protection from an RCD or other 'safety switch' on your mains supply. Make sure the spindle body is well earthed and use insulating sleeving over each connection inside the plug (this will help prevent you detonating your VFD as well). Recent spindles from Huan Yang have the body earthed via a fourth pin on the socket, but earlier versions had only 3 pins or the fourth pin was not connected.
    Kit
    Muzzer's Avatar
    Kit
    I'm afraid that's incorrect. VFDs do NOT isolate the motor (output) side from the mains. So the RCD would provide some degree of protection. So, you should consider the motor phase connections to be at mains potential (which they are) and use appropriate insulation / creepage and clearance distances. A good quality VFD should tolerate a phase to ground short circuit without "detonating". I speak as an engineer who has developed VFDs throughout my career.
    There are some high end industrial installations where the entire VFD high voltage circuit (AC and output) is isolated from ground by means of a dedicated power transformer ("normal" mains is grounded on the neutral side). This is to allow a single fault (phase to ground) to exist without the whole system crashing immediately. These are used in factories such as paper and steel mills where loss of one VFD in a series of interconnected VFDs could be catastrophic. I doubt any of us will ever see such a system.
  5. #15
    Muzzer,
    You obviously have more experience of this than I do. I'll have to do some rectifier drawings and follow the currents.
    Kit
  6. #16
    Muzzer's Avatar
    Generally speaking you will find a bridge rectifier, then DC bus caps, then a 3-phase / 6-switch (IGBT) bridge. Nothing much else needed on the power circuit.
    With single phase 240V input, only 4 of the 6 rectifier diodes get used but as I said, most VFDs don't check for a missing phase. The manual may define a slight derating when you use single phase instead of three phase input but the rectifiers are pretty robust and unlikely to be an issue for intermittent / light hobby use. The DC bus is going to be around 340Vdc and obviously you can't generate an AC voltage that exceeds 240Vac from that, hence you normally need to connect your 3-phase motor in delta if it's a 240/415 star/delta machine.
    On higher power VFDs (>6kW or so), the bridge rectifier will become an active PFC ie another 6 IGBTs instead of rectifiers. And they may then be bidirectional ie can regenerate back into the mains during overrun.
    Some VFDs come with built-in EMC filters but that's the exception rather than the rule. It's a good idea to fit one if you can.
  7. #17
    Thanks for those details. I've been doing some scribbling (it's been a quiet night-shift so far for me here in Australia) and realised that my long held belief that (when considering the operation of an RCD) a rectifier output is isolated from the input just like that of a transformer is so much kangaroo poo. On reflection I can't think where I got that idea which is all the more worrying, I obviously didn't draw any diagrams to prove it.
    Well I did say that my advice wasn't worth the cup of tea Paul would have offered me if I'd visited him in Hampshire
    Kit
  1. can Nema 23's be placed inside box tubing X / Y axis
    By Hulksmash in forum General Discussion
    Last Post: 27-07-2018, 10:42 PM
  2. L gantry design with 2 aluminium beams bolted with T nuts inside...
    By pierantoine in forum Gantry/Router Machines & Building
    Last Post: 30-04-2017, 02:14 PM
  3. Need Help! Gerber System 48 Build Issues Video and Pictures Inside!
    By toby in forum Gantry/Router Machines & Building
    Last Post: 14-08-2016, 01:55 PM
  4. editing files inside solidworks
    By reefy86 in forum Solidworks
    Last Post: 17-02-2016, 12:20 AM
  5. Inside pics of a 3040 300w DC spindle motor
    By Musht in forum Spindles & Drive Motors
    Last Post: 13-09-2015, 07:23 PM
