    Just found this for another member and thought I would share it with everyone else:
    I think generally any of the 30xx machines are ok to use as a learning platform, if users keep things real in terms of what they should expect from these machines it can be a win win situation.
    Engraving copper shouldn't be a problem as its quite a light task to do, for engraving from what I've seen, spindle speed set at around the 10,000rpm mark seems to work well.
    Have you seen this offer, there is 50% off at the moment, free shipping and at only 125 it seems ridiculously cheap not to get one to play around with !
    Sale Link: 3018 3 Axis Mini DIY CNC Router Standard Spindle Motor Wood Engraving Machine Milling Engraver
    Here is a review video:
    .Me
    AndyGuid's Avatar
    Lives in Pakenham, Melbourne, Australia. Last Activity: 43 Minutes Ago Has been a member for 5-6 years. Has a total post count of 153. Received thanks 30 times, giving thanks to others 214 times.
    Would you think that a machine like this would be accurate enough to mark-out the centres of where holes are to be drilled in making Gantry side-plates?
    Sorry but it's like buying a kite to learn basics of flying.
    You need a proper mini mill at least to learn basics of machining. I wouldn't spend a single $ on a stuff like that. Also if you want a laser, buy a laser. All you say is a recipe for wasting money.
  4. The Following 2 Users Say Thank You to Boyan Silyavski For This Useful Post:
  5. #4
    asbo's Avatar
    Lives in Norwich, United Kingdom. Last Activity: 9 Hours Ago Has been a member for 7-8 years. Has a total post count of 47. Received thanks 8 times, giving thanks to others 1 times.
    You can potentially get 6% cashback with topcashback too.
    I think it's worth noting that they say:
    "Engrave Wood, Plastic, Acrylic, PCB, or Similar Material
    Can Not Engrave Metal, Steel, Aluminum."
    So they're honest about its capability, or lack of it.
  6. #5
    These things will engrave metal including stainless you just have to go at it slowly. From my research there is a huge variety of CNC3018-Pro machines out there with differing control boards being the difference.
    Some have later driver chips on with a finer resolution, some appear tohave the row of pins A1 etc on the bottom disabled which is not helpful if you want to use a Z axis mapping function.
    For that reason I shall probably be buying the Sainsmart one which although a little more expensive has the latest iterations of components and supposedly reasonable customer support.
  1. Mini lathe as a 4th Axis
    By Leadhead in forum Gantry/Router Machines & Building
    Last Post: 24-08-2017, 07:53 AM
  2. Free shipping for a year
    By murrayg in forum General Discussion
    Last Post: 13-12-2016, 01:28 PM
  3. TTS type tooling ESS & free shipping
    By komatias in forum Manufacturer News
    Last Post: 10-02-2016, 09:30 PM
