Thread: AXBB charge pump fault
12-08-2019 #11
The coil is reporting around 600ohms with my voltmeter but the battery is about dead so I'm not sure how accurate it is atm. No other isolated outputs are being used on the AXBB at the minute. I have proximity switches on the isolated inputs and a cheap 5 axis Bob for the control panel wiring. I'm wondering if I could use the 5 axis bobs relay as a charge pump to control the safety relay...i can assign it in uccnc but I think I read it can only be used by powering the 5v off usb rather than the boards 5v input.
Sent from my SM-G920F using Tapatalk
12-08-2019 #12
I having read the manual again I see the charge pump controls the damaged output 1
Not all outputs as I thought last night !
which breakout board are you thinking of using ?
To add another charge pump you need to use a breakout board with a built in charge pump circuit or
something like cnc4pc's C4
https://www.cnc4pc.com/c4-safety-charge-pump.html
the detector circuit is hidden under the board !
You need the circuit that controls the relay to ignore static logic levels
and only detect the 10Khz charge pump signal
older version
https://www.cnc4pc.com/pub/media/pro...ser_manual.pdf
John
12-08-2019 #13
In the ucnc software I can configure which outputs to use for the charge pump so I was planning on setting it to the output 17 in the bob which is for the relay or forward reverse control but it isn't switching the relay which is why I think I need to power it from the ish rather than the on-board 5v connectors. I've included the pdf for the bob
I appreciate the help John
Edit.
I should probably add that the bob is connected to port 3 of the AXBB and not to the pc parallel port.
https://cloud.tapatalk.com/s/5d514e97...%20%281%29.pdf
Sent from my SM-G920F using TapatalkLast edited by CharlieRam; 12-08-2019 at 12:51 PM.
12-08-2019 #14
12-08-2019 #15
Oh...my understanding was that the AXBB watched for the signal from the pc and then activates a chosen output for the charge pump. In my case it would be pin 17 controlled through the AXBB's 26pin idc to the bob which would then switch the onboard relay on to complete the circuit to power my safety relay for the drives.
Am I understanding it wrong? There should be no random outputs on the AXBBs port 3 lile would be on a pc's parallel port on start up or at least that's what I assumed.
12-08-2019 #16
last night I expected the AXBB to work as you described but after downloading the manual
at the bottom of page 19
8.1.1 .Digital isolated ports.
Port#1 pins 2. to 8. are isolated outputs. These outputs contain high speed 10Mbit/sec
optocouplers and an N-channel Mosfet transistors.
The outputs can drive upto 500mAmps of current upto 24Volts voltage levels.
The high current capability of the output transistors makes these outputs ideal to drive
relays, solid state relays and other signals which require isolation.
19/29
on page 21
8.3 .Charge pump safety circuit port
There is one charge pump safety circuit integrated on the board in port#1 O1 CHP output.
The charge pump circuit senses the charge pump pulse stream signal from the controller and
if the signal exists then the output is switched on and if it cuts then the output switches off.
The charge pump can be used to control a safety relay to cut power when the software is not running on the computer.
Unless I have missed it
I have not seen an explicit ref to all output being switched off as I would of expected
My be another AXBB user can confirm
John
PS
have you contacted the manufactures ?
12-08-2019 #17
I think I will have to, I just wanted to check I hadn't missed anything. It was working fine and I'm not sure when it turned faulty but noticed a few days ago that it started straight away
it seems strange that the software will allow me to choose any output for the charge pump though.
Cheers for the help
13-08-2019 #18
So I got a response that it could be the input transistor. I have asked whether it is covered under warranty but haven't had a response yet however I decided to check the values myself and the resistors seen in the pic below should be....
30B=2k
221=220ohm
01C=10k
All the values are correct other than the one circled which gives more like 1k value so in your opinion is it blown or do you think there is a path from elsewhere?
Edit
How easy is it to replace a faulty smd and what would be an acceptable cost at an electronica shop? I'm just wondering if the cost will be cheaper than shipping back to CNCDrive.
Sent from my SM-G920F using TapatalkLast edited by CharlieRam; 13-08-2019 at 03:53 PM. Reason: Additional question
13-08-2019 #19
I've seen people replace them with a thin tip soldering iron, a pair of tweezers, a steady hand and a magnifying glass. Read a tip in the UB1 manual today that said disconnect your iron from the mains and then ground it once it's at temperature. I'm sure you'll find examples on the old YouTube.
Sent from my SM-G950F using Tapatalk
13-08-2019 #20
The smt resistor coding used is this -
https://www.hobby-hour.com/electroni...-resistors.php
So far I have not found the transistor marked A66
I thought it would be something like a high current version of a 2N7002
https://uk.farnell.com/search?st=2n7002
http://www.farnell.com/datasheets/22...4aAiVAEALw_wcB
may be a
FDN337N - MOSFET Transistor, N Channel, 2.2 A, 30 V, 0.065 ohm, 4.5 V, 700 mV
is closer to what we are looking for
https://uk.farnell.com/on-semiconduc...-23/dp/9845356
could you post some wider pictures to see more of the circuit connections
to see what its connected to
usually I expect resistors to go high resistance when overloaded and semiconductors to go short circuit
JohnLast edited by john swift; 13-08-2019 at 04:51 PM. Reason: add ref to change in resistance
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Not sure where the fault lays
By terry1956 in forum VectricReplies: 5Last Post: 20-02-2019, 11:28 AM -
fault testing
By Palletlad in forum General ComputingReplies: 2Last Post: 09-02-2018, 05:51 PM -
Jun-Air Compressor Fault
By jamesgates1000 in forum General DiscussionReplies: 5Last Post: 02-12-2017, 07:59 PM
