Thread: About homing and switches...
05-09-2019 #31
So, anybody got a good source for proximity sensors?
As i have understood, im in the market for the inductive kind. 4 mm sensing distance would do it and NPN/PNP should not matter with the Csmio IP-M. Emergency switch, some resistors and a main switch is also on the shopping list right now...Last edited by JW1977; 05-09-2019 at 08:08 AM.
05-09-2019 #32
it depends on the budget your working to
if its a hobby machine then try amazon or ebay etc
buy 1 to check the quality then order the others you need
for a business machine you use to make a living
look at industrial suppliers like RS Components , Farnell or Rapidonline
for original proximity sensors not the cheep clones found else ware online
you will pay more but they will be to the published specification
example
https://uk.farnell.com/multicomp/mcp...imity%20sensor
John
PS
after looking at your location
https://se.farnell.com/
https://se.farnell.com/multicomp/mcp...weden%2FsearchLast edited by john swift; 05-09-2019 at 04:57 PM. Reason: add example link to https://se.farnell.com/
The Following User Says Thank You to john swift For This Useful Post:
05-09-2019 #33
Don't waste money buying the expensive switches Just buy the cheap Chinese switches off ebay.
I've fitted 100's and probably had about 3 in total that was faulty out of the bag. I've had about 5 fail in use over a 10yr+ period all on different machines.
The accuracy is more than good enough for any Router or DIY Milling machine.
The IP/M doesn't care which you use but I always fit NPN switches.
05-09-2019 #34
05-09-2019 #35
Maybe you got confused with all the chatter of 10k internal resistors, pull-up resistors and so on. You paid good money for a quality controller and therefore the prox sensors just plug straight in !
I think I used resistors on the 12V front panel LEDs to run off 24V but that depends on how, or if , you want indicator lights for status and so on. For example they can also be mains powered indicator lights.
06-09-2019 #36
Sorry guys, fuses, not resistors! Theres a lot on my mind right now...
However, havent got to it yet, collecting the final parts right now but, i read about one resistor in the driver manual.
Remark:
VCC is compatible with 5V or 24V;
R(3~5K) must be connected to control signal terminal.
If im not mistaken i think i read about it in in the Csmio manual also but they recommend a 2K resistor there!?Last edited by JW1977; 06-09-2019 at 07:33 AM.
09-09-2019 #37
Couple of odd comments:
IP/M is very happy with direct connection of prox switches running on 24V. Works well.
IP/M drives the usual stepper drivers directly without needing any resistors. Use differential connection if your drivers support this - better noise resistance.
Unlike Jazz, I've not been too lucky with prox switches from eBay. I bought a box of ten. One was the wrong type (unbelievable! Two-wire, quite obviously not the same as the rest of the 3-wire switches), one was faulty straight from the box, and one failed very shortly after fitting. However, the rest have been working fine for a couple of years now, and the whole box probably cost less than one "professional" quality switch. That's the difference between home building and commercial - commercial machine could not stand that level of quality, but it suits my pocket!
09-09-2019 #38
I too bought a box of 10 from China.
The machine I have from MD had end-on axial sensing and I crushed a sensor whilst jogging (the machine, not me!), In my naivety I ordered a replacement from MD and it cost £17.50 (ouch, ouch,ouch). When I crushed that one, I ordered 10 from China and converted the sensing to bypass.Some have orange sensor ends and a grey cable and some have blue ends and a black cable. I have 9 of them left. They are all NO and 4mm.
Cheers,
Rob-T
09-09-2019 #39
I also have had about 30 from AliExpress with no duds with pnp and npn types.
09-09-2019 #40
My chicom mechanical switches are quite reliable, omron copies.
They are not too accurate, and the mechanical assys are terrible, in terms of machinist parts.
0.01-02 mm +/- in repeatability/accuracy is terrible.
For my cnc lathe, industrial quality.
But for routers, they are much more than good enough.
(My lathe is for sub-micron or 1 micron repeatability.)
Cheap 5$ optical limit switches provide about 2 microns accuracy, fairly easily.
G540, homing switches and mach3
By marbles in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 02-06-2018, 02:55 PM -
Problem with homing
By Andyman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 22-03-2016, 07:56 PM -
Homing switches & 'methods of working' (Mach3)
By HankMcSpank in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 19-10-2012, 12:54 AM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM -
A simple query about homing switches & milling practise
By HankMcSpank in forum General DiscussionReplies: 5Last Post: 13-06-2009, 11:56 PM
