18-08-2019 #1
Hi All
I have just installed the HY01D523B inverter and it drives the 1.5Kw motor ok but I wish to control the spindle on/off from a breakout board having a motor control relay. The diagram in the inverter manual shows the relay switching between FOR and DCM(COM). My relay is switching ok and the wiring is also ok so I think that the inverter settings are not correct. Does any one know what parameters need to be set to activate this function?
JimK
18-08-2019 #2
You have to go into the inverter settings and set pd001 to 1. This means start stop is controlled externally. See the manual for which buttons to press to get into the menu.
Vfd settings
By kwsb246 in forum General DiscussionReplies: 2Last Post: 07-02-2019, 08:38 AM -
Huanyang VFD dl Error
By charlieuk in forum Spindles & Drive MotorsReplies: 7Last Post: 12-05-2017, 07:59 PM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM
