    Not sure what you mean by this
    easier if you can get a twin-sensor coupler with a pitch smaller than the hole gap space
    re the 64 pp rev you you want it for threading then you won't be running the spindle fast. I think I have tested it at about 600 rpm. 64 was just the number I drew the disc in cad. you could also just use one sensor on the disc and another on a tooth some where as long as it is 1:1 with the spindle.
    When I change the motor I might have a go at CSS (constant surface speed) with a VFD for the fun of it.
    With the 3 sensors like mine it could do rigid tapping. Although I have never done it on the lathe.
    Edit re the mpg's I used the same mpg's between the mill and the lathe with the same control box with 5 drives in it and one mesa card (using only one machine at a time)
    Something like the TCUT1800X01,
    This has 4 detectors at differing X/Y positions capable of quadrature encoding with index pulse.
    Now that I've bought 10 of the little darlings I think I might need to upgrade my soldering iron. Or microscope. Or both.
  1. Convert Sketchup drawings to CNC ?
    By DaveEP in forum Sketchup
    Last Post: 25-08-2018, 05:52 PM
  2. Convert the milling into a CNC machine
    By jfroux_1 in forum Tool & Tooling Technology
    Last Post: 19-08-2018, 09:23 PM
  3. Best way to convert a vmc190
    By franky in forum Milling Machines, Builds & Conversions
    Last Post: 29-01-2017, 01:44 PM
  4. how do you convert a .png to a .tap file?
    By valeria caltabiano in forum General Computing
    Last Post: 16-02-2015, 01:25 PM
  5. how to convert a mill to cnc?
    By speedhound in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2010, 09:07 PM
