Page 2 of 2 FirstFirst 12
    Do you know if the encoder below are quadrature type?
    Accu 755 1000 pulses/rev
    Would you recommend to follow this route to a newby or the risk of failure is too high?
    Quote Originally Posted by agors View Post
    I would guess that is a quadrature output incremental encoder, however searches have not found any manuals for a 755 encoder.
    How many wires does it have?
    Ideally you want encoders with differential outputs, which means you're looking at a minimum of 6 wires (+V, Gnd, A-, A+, B-, B+), plus possibly an index pulse (Z-, Z+).
    Everything has the potential for failure, but provided you're willing to learn, then most things are possible.
    9 wires;
    I’m a bit worried to follow a servo based approach;
    I’m uncertain on what to do...
    Hey Welcome to the Rye club from New Zealand!
    Here is my Rye MG3000 which we acquired about a year ago. I am currently doing a full rebuild and retrofit of the control systems, moving to a DSPMC/IP, keeping the original Servo amplifiers and Tachometers in place. There is a lot of work in it!
    Hope all goes well with your machine they are quite rare!
  5. #15
    Here I’m with some updates;
    all new electronics and motors;
    looking at the coupling
  6. #16
    Today I worked on some stuff mainly for safety;
    - plaque to allow the motor to sit perfectly flush on the Cnc frame (there is a 2mm step on the moto housing)
    - cover for the power supply, so that the risk of touching the 220v cable is lower;
    - case for the BOB (not my design)
    I’ve also made a mask so that the new motors will be perfectly centered respect the old motors.
  7. #17
    More things done, soon other updates
  8. #18
    machine perfectly running thanks to a colleague
  9. #19
    Quote Originally Posted by Thomas.f View Post
    These bring back fond memories i operated these machines for some years.
  1. BUILD LOG: Finished builds picture menu
    By routercnc in forum DIY Router Build Logs
    Last Post: 05-12-2021, 12:28 PM
  2. NEW MEMBER: New member AGORS
    By agors in forum New Member Introductions
    Last Post: 10-10-2019, 09:50 PM
  3. picture conversion to DFX/ Gcode. Help required please.
    By Gasgasbones in forum Programmers Corner
    Last Post: 19-12-2014, 11:42 AM
  4. Microcarve picture carving software
    By cnctoybox in forum CAD & CAM Software
    Last Post: 26-03-2012, 07:00 PM
  5. Router/Spindle choice for Makita laminate trimmer upgrade
    By CraftyGeek in forum Makita Routers & Trimmers
    Last Post: 30-11-2009, 11:23 AM
