    Guys - looking for someone who can machine an ally enclosure between the following min/max dimensions:
    ....... contacted 32 companies in the UK who advertise steel and alloy die cast enclosures for sale - not one could offer an enclosure between these sizes :whistling:.......... (yer, what's become of UK manufacturing? - that new steam engine that's just been built in the UK - we had to get the Germans - the Germans!!! - to make the boiler - this country, used to be the world leaders in steam engine design/construction)
    Length (internal): 300mm 310mm (min max)
    Width (internal): 100mm 110mm (min max)
    Depth (internal): 32mm - 36mm (min max)
    Wall thickness: 3.5mm - 4.5mm (min -max)
    Lid to go on top required - same thickness as enclosure wall thickness.
    Aolly type: 6061, 7075 ... whatever, makes little difference.
    If anyone out there is willing to take this on, drop me a note please. No such thing as a free lunch ... yes, thats understood.
    Quite happy for someone to take this on on a "hobby" basis - theres no IP or DIN spec, or any other spec that has to be satisfied.
    Thanx guys
  2. Quote Originally Posted by benbenrf View Post
    Thanx guys
    Would it be acceptable for the base to be removable as well as the lid? Is there any special requirements for the corners - must they be square (internal and external), or could they be radiussed (essential if machined)?
    Irving2008
    Nope - no probs if the base is removable, and there is no issue regards edge radius - square, rounded .. whatever - use whatever tool you have. I'd say from true square to as much as 2mm - 3mm will be fine.....
    What do
    What do you have in mind regards fixture for top/bottom lids (?)- so long as the wall thickness is sufficient for small self-tapping type screws, that will be fine as I intend to cut a gasket in any case.
  4. Have a look at Penn Fabrication's Module stage box system
    A couple of lengths of their corner extrusion and a few plates of aluminium and bob's yer uncle...
    Retail quantities can be bought from CPC:
    http://cpc.farnell.com/_/10345-20/co...ule/dp/EN55970
  5. I was trying to find 300 x 100 x 3.2mm ali box section but no one does it that size in ali only in steel.
    machining it out of 1.75" ally plate is a possible, but its 25 worth of ali. However if you plunge cut it all the way through with a 10mm cutter at least you'd end up with an approx 280 x 80 remnant which is useful; then make top n bottom out of 4mm plate.
    Another option is to make it up from 4mm plate and weld up the corners... then machine clean
    Gosh that's brave, how are you going to hold it down and stop it bending away from the tool/galling once the temper has gone :naughty:
    32mm deep doesn't exactly lend itself to small internal corner radii and the spec is too loose. Sounds like an invitation either to do a lot of drawing and not get the job, or chop up 25 worth of stock and then get told it's all wrong. I can see why he's having problems finding a volunteer :whistling:
  7. Quote Originally Posted by Robin Hewitt View Post
    Well, strangely enough, I was looking into ali welding for another problem and i came across Durafix which might do the job. Anyone used it?
    I bought some but haven't tried it yet. May be one of those you buy which look useful but never actually use :naughty:
  9. Your local waterjet shop should be able to sort that, probably for cash if you supply your own material. Base would need to be removable as said before, internal radius 0.5mm min and width of cut 0.8mm so you get back a nice lump to make something else out of. Our customers often get us to rough pockets in 50mm stainless just so they can use the 'pocket' for another job. Better than turning it into swarf!
    All the best.
    Ken
  1. Looking for a dremel sized cnc router
    By isdngirl in forum Marketplace Discussion
    Last Post: 28-04-2014, 11:01 PM
  2. RFQ: Some simple PAID precise Aluminium CNC work required completing? ANYone?
    By justice86 in forum Projects, Jobs & Requests
    Last Post: 03-12-2013, 07:12 PM
  3. FOR SALE: Nice aluminium rack mounted enclosure, possible casing for cnc electronics
    By drumsticksplinter in forum Items For Sale
    Last Post: 23-08-2013, 11:48 PM
  4. Imperial sized lead screws?
    By fentiger in forum Lead Screws, Nuts & Supports
    Last Post: 14-06-2013, 09:16 PM
  5. RFQ: Need protective enclosure made from solid aluminium.
    By Tinine in forum Projects, Jobs & Requests
    Last Post: 12-02-2013, 08:12 PM
