Page 2 of 2 FirstFirst 12
    Nope.
    Bobcad, Alibre and Solid Edge can't open it.
    It's a simple 2 D shape, why not draw it as 2D ?
    Laser cutters only read 2 D files.
    John S -
    Can't open it here either.
    May be quicker to re-post the original drawing that you did but dimension it up, that way I can re-draw it.
    Steve.
    This is so annoying!
    It just seems stupid that I spent all that time making the part, and then I have to make another drawing only for someone else to make another!
    One last go... I messed around with settings, tried a bunch of different formats... hopefully something works.
    If not I'll knock up the drawing this afternoon.
    Attached Files Attached Files
    Hurahhh!
    I think I have finally got it!
    It occurred to me whilst in the shower (I find the bathroom a great place to solve problems). DXF is a 2d format, yes? For some reason when I import my Maya file into Rhino it gets rotated 90 degrees so that when you look at it from the top all you see is line! So I thought maybe I need to rotate the object so that the drawing can be seen from the top view port, and sure enough I can now see the drawing in eDrawings viewer. So fingers crossed this works.
  5. #15
    Are you sure you want it 134" long ?
    John S -
  6. #16
    134mm...
    u sure thats not to do with your import settings, or the units the prog is set to use?
  7. #17
    John, you are wrong its not 134 inch's long.
    Its 3.4m!
    Leave it with me, I will sort it out.
  8. #18
    I have done somthing along these lines, sorry to hijack !
    How do you plan on keeping this little lot + BOB and PC cool? Looks like you have the same Zapp kit as me and it gets pretty hot I can tell you! I have finally managed to get the three 120mm fans in my case working and although it's a bit noisy, everything stays very cool indeed now.
    Jeff.
  9. #19
    I have 2 boxes under my machine and I would prefer to have a setup similar to what you have down.
    I would sure like to see the build log for that PC/controller Lee.
    Any chance of you posting a build log?
    Thanks, Keith
    Life lesson number 1: If your not enjoying it your doing it wrong...........
    Life lesson number 2: Refer to Life lesson number 1...........
  1. Replies: 1
    Last Post: 13-02-2014, 02:40 PM
  2. RFQ: Prototype keyboard case - CNC and laser
    By Photekq in forum Projects, Jobs & Requests
    Last Post: 26-05-2013, 07:18 PM
  3. Drivers,BOB and PSU are in a PC case, do i earth the case
    By deannos in forum Motor Drivers & Controllers
    Last Post: 27-11-2011, 02:43 PM
  4. RFQ: Project Case End Plates Require Making
    By flipflop in forum Projects, Jobs & Requests
    Last Post: 17-08-2010, 08:03 AM
  5. Controller box from PC case
    By Smiler in forum Electronic Project Building
    Last Post: 24-12-2008, 02:46 AM
