    Hey,
    because now I miss access to a CNC milling machine (in my previous job I had access to an "Ergwind MFG 4025" milling machine), I want to build my own CNC milling machine.
    I want to use it mainly as a hobby and amateur (not 8 hours a day), to work mainly with aluminum - cutting emblems for classic cars, making custom details / parts, such as this air filter housing, etc.
    https://www.instagram.com/p/1Objgml4py/
    The cutters used are mainly diameter 1-3mm maybe 5-6 (with small depression)
    Working area about 600 x 400 x 150 - but maybe a little bigger
    Before I start buying parts and putting them together, I have a question for you which solution will be the best?
    I am thinking of a solution similar to this:
    https://www.instagram.com/p/B4iQNFeqwFu/
    My assumptions are:
    - lower base frame - aluminium extrusion profiles 80x80 Item or similar
    - gantry profile - 80x160
    - side support of the gantry made of aluminum plate (20mm?)
    - one or two? ball screw 1605 for X axis
    - spindle 2.2kW chinees
    - hiwin linear rails
    At the moment I have 4 hiwin qhh15ca Z0
    whether to use them for the Y and Z axis, and for the X axis buy qhh20?
    Or use them for X and Y and for Z buy qhh15ca ZA ?
    That's it for the moment, if I remember something else, I will write it.
    Are these my plans ok or should I change my assumptions?
    Thanks for your help and best regards
    After reviewing the projects on this forum, at the moment I will probably choose a version similar to the project made by 'devmonkey' ("Joe's 1000x600x200 steel and aluminium router started"): extrusion gantry and welded steel frame
    I started to draw from the Z and Y axes, and I have such a concept:
    I am still thinking about mounting Y linear rails: as I drew in the picture or maybe I should move them to top and bottom?
    I already have my project, but I am thinking about one more thing: connection of the gantry profile with cariage
    At the moment they are 15mm aluminum plates, but I am wondering about steel sheets with keyway and welded connection
    Maybe someone used this solution? or rather only aluminum plate?
    @szecho, I've seen plenty of machines on this forum using a similar design to what you have decided on, and the recommendation seems to be to use 20mm Aluminium Plate if possible.
    It looks like you have the opportunity to bolt through from the horizontal carriage plate to the bottom of the gantry extrusion - this will greatly rigidise the axial movement of the gantry and reduce the requirement for the side plates over a design where the gantry extrusion is well up in the air and the side plates are taking all the strain. Regarding position of the rails on the gantry, top and bottom spaces them further apart than on the front giving the opportunity for greater rigidity and keeps the Z axis assembly close to the gantry, but it will lose you clearance in the Z axis. Top and front (bottom) is an in-between solution that some people use.
  1. Router losing steps. Solution needed. Will this help?
    By cncbobuk in forum Chinese Machines
    Last Post: 27-12-2017, 03:40 AM
  2. FOR SALE: For Sale - Small D/Top CNC/Mach3 router
    By Leadhead in forum Items For Sale
    Last Post: 04-07-2016, 02:35 PM
  3. BUILD LOG: Small CNC Router
    By Plantationpark in forum DIY Router Build Logs
    Last Post: 22-02-2016, 12:22 AM
  4. Small Gantry Router
    By mike os in forum Gantry/Router Machines & Building
    Last Post: 08-01-2015, 07:02 PM
  5. WANTED: Wanted small cnc router
    By lukecnc2012 in forum Items Wanted
    Last Post: 10-10-2014, 06:51 PM
