    Hi, I finally dug my machine out and got it running, have a DDCSV 2.1 on the machine now
    What's going wrong?
    Mechanical or software?
    It's meant to look like this
Name:	Test piece fusion.png
Name:	Test piece fusion toolpath.png
    I cut it once, let the cut finish. Turned the power off and on again to machine and then repeated the same cut again next to it to see if I was losing steps.
Name:	Test piece cnc.png
    2 cuts look identical to me.
    I used Fusion 360 to generate the Gcode.
    I have AM882's which have fault protection and if you drive them too fast they do fault but running the cut very slow 1m/min not getting any faults
    Adaptive clearing and contour for finishing pass.
  1. Mach3 Problems problems problems.
    By ECCO in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2016, 10:07 AM
  2. circle cutting mach 3 problems help please
    By millmateuk in forum Artsoft Mach (3 & 4)
    Last Post: 13-06-2013, 07:04 AM
  3. Cutting problems on a gerber
    By martin54 in forum Machine Discussion
    Last Post: 01-06-2013, 09:07 PM
  4. Big problems with cutting HDPE can you help?
    By Nathan_Partington in forum Machine Discussion
    Last Post: 11-05-2012, 09:44 AM
  5. NEW MEMBER: MDF Problems
    By MrWiz73 in forum New Member Introductions
    Last Post: 31-12-2011, 12:39 AM
