Page 2 of 2 FirstFirst 12
    Ok I misunderstood. Thought you were converting completely to belt drive not just wanting to connect motors. Forget what I said that doesn't apply in this case.
    Still use HTD thou.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #12
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    I'm using 18 tooth HTD pulleys for exactly this from belting online with 2x M4 grub screws. Seem to do the job so far. Model number (18-5M-15F) (HP18-5M-15F)
    I think I remember from figuring it out at the time you want as many teeth in contact with the belt at once to reduce backlash, so larger pulley the better, but also you want flexibility to increase or reduce the ratio later on without having to buy all new pulleys for everywhere.
  4. The Following User Says Thank You to AndyUK For This Useful Post:
  1. 6m X axis Rack and pinion or belt drive?
    By charlieuk in forum Rack & Pinion Systems
    Last Post: 02-07-2020, 01:22 AM
  2. BUILD LOG: belt drive to ballscrew drive changeover advice required
    By marbles in forum DIY Router Build Logs
    Last Post: 14-02-2020, 02:14 AM
  3. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  4. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 08:44 PM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
