Page 14 of 14 FirstFirst ... 4121314
  1. #131
    I have a video, but it's fuzzy and noisy... but if it helps I'll throw it onto YouTube. But, I think I can describe it easily enough:
    No comms: Green power light on board, green carrier light as one of the two integrated LEDs on the RJ45 socket.
    UCCNC starting up: Blue light on board illuminates. Orange activity light in RJ45 flashes 3-4 times a second, continuously.
    UCCNC operating: As above.
    UCCNC shutdown: Blue light, and orange light extinguish.
    Thanks so there is a light on next to the RJ45 socket with no comms but it goes off after running and exiting UCCNC?
  2. #132
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 3 Hours Ago Has been a member for 6-7 years. Has a total post count of 798. Received thanks 128 times, giving thanks to others 34 times. Referred 1 members to the community.
    Sorry, the green light on the board remains on throughout, comms or no comms.
    The blue light on the board is on only whilst connected to the software.
    This is a UC300ETH, btw, not an AXBB.
  3. #133
    Thanks. I have just re-RTFM and found:
    The green LED in the RJ45 connector is the 'Link' Led which lights when there is an active
    connection to the computer or switch/router. If the green LED is off when the LAN cable is
    connected to the computer and the AXBB-E board is powered then there is a physical
    connection problem, the cable might be broken or has the wrong pinout.
    The orange LED is the 'Activity' LED which lights when packets being received or
    transmitted by the device.
    And the green light goes off on mine. My parcel is due before 11am tomorrow so I will have another look as I can't say I have seen an orange light BUT probably not looked at it when it has connencted. I have also now got another spare hub to try.
  4. #134
    Quote Originally Posted by ngwagwa View Post
    The 2 readings of 2.4 were pairs from the stepper disconnected from everything else. The 0.4 on the purples I am not sure now as I only disconnected 1 of them so I knew which was which - I will double check the purples and try and trace then tomorrow providing UPS deliver in the morning otherwise it will be Saturday.
    So out of stepper I have 6 wires 2 pairs each with a resistance of 2.4 and two purple wires with a resistance 0.4. The 2 pairs are connected to the drivers and i have (so far) been unable to trace the purple inside the cabinet but they are not connected together and there is no connection between the 2 puple and the other 2 pairs.
  5. #135
    I've tried reading around while I'm bored and didn't get very far. All I've got is:
    6 wire steppers can be wired Unipolar or Bipolar(series).
    My guess is it's in series and NC means not connected?
  6. #136
    Quote Originally Posted by dazp1976 View Post
    That's the configuration on my X Axis (I found out thanks to JAZZNC and Doddy) it was originally wired A+ to COM and B+ to COM so we changed it as per your diagram.
    Thinking the Y and Z axis would be the same I was examining the wires on the Z axis (typo earlier) but all I could find were two pairs with a resistance of 2.4 and the 2 purple with a resistance of 0.4,
  7. #137
    Many thanks to everyone especially Doddy and JAZZCNC for all the assistance given and my Denford Router is now much improved with a new 65V power supply, digital drivers, AXBB motion controller with UCCNC at the front end. Along the way I have been introduced and educated in many of the intricacies of CNC control that prior to this were black magic. I am now cutting metal and have only one more piece of the black art to come to grips with which I have posted in the UCCNC section of the Machine Control Software section.
  8. #138
    Doddy's Avatar
    You'll be back! <manical snigger>
  9. Sorry, i posted before reading every page.
  1. Losing steps
    By Edendale in forum General Discussion
    Last Post: 06-03-2020, 09:10 PM
  2. Weird noise on travel and losing position
    By ngwagwa in forum Artsoft Mach (3 & 4)
    Last Post: 07-02-2020, 04:45 PM
  3. Router losing steps. Solution needed. Will this help?
    By cncbobuk in forum Chinese Machines
    Last Post: 27-12-2017, 02:40 AM
  4. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 09:49 AM
  5. New Mill losing steps
    By lukecnc2012 in forum Gantry/Router Machines & Building
    Last Post: 08-11-2014, 01:56 PM
