Thread: Hi Everyone
    Hello Everybody I found your (Our) site about a week a go and have just registered. I am looking to build a cnc mill capable of machining Ali/Brass:wave:
    Welcome Peter
    When you start your build don't forget the photo's
    Andy
    Kn8's Avatar
    Location unknown. Last Activity: 10-11-2014 Has been a member for 7-8 years. Has a total post count of 58. Received thanks 1 times, giving thanks to others 0 times.
    Hello Peter, welcome.:wave:
    Ivan
  4. Quote Originally Posted by Peter Griffin View Post
    Welcome Peter.
    Can you be clearer about your goal?
    Sorry if you know all this already, but here are some thoughts you might find useful.
    Do you mean a router, or a true mill? Generally with a router the cutting head moves in X/Y/Z and the workpiece remains stationary, which is good for large wood/plastic/foam items. In a mill the cutter moves in Z, but the workpiece moves in X & Y, whcih is better for smaller items, particularly metal ones. Obviously there are cross-overs between these.
    For cutting metal (with any reasonable speed or depth of cut and accuracy) you need rigidity which is generally hard to achieve with a router arrangement without incurring a lot of hassle and cost. A true mill is characteristed by a lot of mass in a big casting to give the rigidity, and therefore most CNC milling is done by converting a conventional off-the-shelf mill rather than building from scratch (although I have seen some ground-up builds based on a lump of steel girder). This is likely to be the cheaper route overall as well.
    Thanks all for the warm welcome, In reply to irving2008 I hope to build a gantry type milling M/C based on a welded steel chassis (X750, Y500, Z125) I have got a fair idea of how it will look,but still in the drawing stage.
    Hi Peter, good luck and welcome mate !
