Thread: Confused again!
Page 2 of 2 FirstFirst 12
    Quote Originally Posted by Buba b View Post
    With the quick go the 1/1 its not even close to measurement and 1600/320 was interesting until it didn't move at all , but i need to get in and play more when cooler and have another scan through the manual .
    That's about what I would expect with using steppers because the Encoder parameters will be much higher, probably something like 2500 by default, which is a standard Encoder base count. This could also easily be x4 because encoders are quadrature and it probably uses the base pulse rate.
    If you can point me to the manual I'll take a look.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    Jazz, YGM (or you should have, unless it's gets bounced back for being too big!)
    Cheers M i'll take a look later.
    I think you need to change the encoder wire parameter (2-29)
    I did try attaching the PDF, but I think it's too big for the forum to accept :-/
    Ok I agree with M_C try setting parameter (P2) 29 to = 80. This is 320 / 4
  5. #15
    I changed the 2-29 to 80 and the Num / Denom to 1/1 and no change still out but I'm going to have a look when I've got time at the weekend .
    So just for interest I found a blog with a guy setting up a Newker control , cant believe it much different and he's setting up a 4th axis with a stepper motor
    https://mightyshiz.blogspot.com/2018...ewker-cnc.html
    He says :
    "The units are important too. I have 2000 steps per turn set up on the stepper driver and the controller seems to generate 4 pulses per "step", so I need 8000 on the numerator and 1900 on the denominator (# in "axis" parameters). Not clear quite how all that works but certainly, the indicated units for the A axis correspond with degrees movement on the table."
    Now i haven't got into reading too much yet but it was interesting that he's got the big numbers in numerator and denominator rather than the 1/1 .
    So I'm going to bash google as I cant be the only muppet running one of these with steppers ......or can I .....hmmm!
    Some guy called Muzzer ?? .....now where have I seen that name before !
  1. Getting started and already confused
    By Palletlad in forum General Computing
    Last Post: 12-01-2018, 11:00 PM
  2. Confused about stepper sizing
    By Jeff in forum Gantry/Router Machines & Building
    Last Post: 29-09-2017, 08:14 PM
  3. New Build Advise Ive Got Myself So Confused ! Please Help !
    By grain_r in forum Gantry/Router Machines & Building
    Last Post: 26-07-2014, 01:21 PM
  4. Confused need help!
    By manofgresley in forum CAD & CAM Software
    Last Post: 08-08-2012, 08:30 PM
  5. NEW MEMBER: New and confused!
    By nicodemus in forum New Member Introductions
    Last Post: 10-07-2011, 12:12 AM
