Hi
If the dowel wood is green you can try putting the dowels in an oven or micro wave ( you'll have to experiment a bit on how long and how hot, but it should get you out of trouble. If you have any kind of table disc or belt sander you could rig up a v block jig and roll the dowels against the sander.. One final method take a piece of your dowel, screw a woodscrew into the end of it (as central as possible) leaving15mm stickng out, cut the head off ,chuck it in a drill and run it against some coarse sandpaper making a very slight taper till it's small enough to fit your holes plus a bit extra for the thickness of your sandpaper , super glue some sandpaper on the dowel and enlarge your hole to taste .
Andrew
27-07-2020 #3
Hey you guys are smart :)
I'll try to remember to report back after I try those methods.
Thanks, Alan
Runout, HSS drills and dowel holes
By hoezap in forum Metalwork DiscussionReplies: 2Last Post: 08-03-2017, 12:36 PM -
Dowel holes reamer or interpolation?
By hoezap in forum Metalwork DiscussionReplies: 4Last Post: 10-04-2016, 12:44 AM -
dowel pins & corresponding drill sizes to get a tight fit....
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 7Last Post: 04-07-2013, 08:50 PM -
Dowel Pin Drill jig
By Lee Roberts in forum Programmers CornerReplies: 0Last Post: 14-10-2008, 02:34 AM
