    I have some slots/holes (typically 2....3mm wide) to do pretty accurately in a number of pieces of 80% nickel sheet, so the CNC's the obvious go-to. I was told by the supplier that it's a bastard to work with, does anyone have any experience of this please? I'm guessing it will be a bit like stainless & work harden rapidly hence you need to press on mercilessly, but if anyone has any info on speed & feed I'd be very grateful, thanks.
    Hi, i work with nickel alloys on a daily basis.
    Yes it will work harden rapid with that specific grade. That grade can often cut like aluminium, and clog up 4 flute cutters.
    We tend to mill much larger than 3mm. However we have found 2 flutes work well. As for feeds & speeds, i would aim for a slightly higher feed than you would for stainless.
    As you mention you need to press on merciless with it.
    I find carbide or HSS tools work well.
  3. The Following User Says Thank You to TheHybridOne For This Useful Post:
    Cheers for the advice - I'll try some 2 flutes next time I have to do some parts.
  1. 600LBs cast iron monster !!
    By VulcanMachineCo in forum Manufacturer News
    Last Post: 30-01-2019, 07:05 AM
  2. RFQ: Marking a cast iron
    By mike stat in forum Projects, Jobs & Requests
    Last Post: 13-09-2012, 10:22 PM
  3. RFQ: Small parts CNC machined from iron
    By luc in forum Projects, Jobs & Requests
    Last Post: 20-06-2012, 09:24 PM
  4. What is the best sheet alloy for machining?
    By p1lts in forum Metalwork Discussion
    Last Post: 09-10-2011, 11:37 AM
  5. Temperature Controlled Soldering Iron
    By M250cnc in forum General Electronics
    Last Post: 17-01-2011, 02:01 PM
