Page 11 of 14 FirstFirst ... 910111213 ... LastLast
  1. #101
    First we put the flange on the machine and made holes in it so we can use them later as a center for alignment for milling the arcs of the part.
    And start with roughing .
ID:	3064   Click image for larger version.
ID:	3063   Click image for larger version.
  2. #102
    After making sure the workpiece is in the center of the machine I started with
    roughing the outer arc.
ID:	3069   Click image for larger version.
  3. #103
    After that we are roughing the cylindrical section and then turn over the workpiece and cut away the biggest arc.
    But first we made the small arc .
ID:	3072   Click image for larger version.
ID:	3070   Click image for larger version.
  4. #104
    After finishing the outer arc the arc shaped slots ware made.
ID:	3073   Click image for larger version.
  5. #105
    In a later stage the piece is taken in the chuck of my lathe.
    The first operations are facing of and drilling .
ID:	3075   Click image for larger version.
ID:	3076   Click image for larger version.
  6. #106
    With a other tool we made the chamber for the motor.
ID:	3078   Click image for larger version.
ID:	3079   Click image for larger version.
  7. #107
    After turning over the workpiece the other side is machined .
  8. #108
    Now the workpiece is going back to the milling machine and it is centered and holes ware made in to it so the motor can be attached .
ID:	3082   Click image for larger version.
  9. #109
    In to the side of the flange a tapped hole is made to attach a handle for tightening the belt of the motor.
  10. #110
    now the motor flange is ready for paint.
ID:	3085   Click image for larger version.
  1. CONVERSION: Archdale Conversion
    By meyerga00 in forum Conversion Build Logs
    Last Post: 17-06-2012, 09:24 AM
  2. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  3. Bridgeport Conversion
  4. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
  5. A little conversion tool
    By D-man in forum Computer Software
    Last Post: 18-12-2010, 04:58 PM
