    depronman's Avatar
    Lives in St Annes on the Sea, United Kingdom. Last Activity: 44 Minutes Ago Has been a member for 5-6 years. Has a total post count of 159. Received thanks 19 times, giving thanks to others 6 times.
    I think I’m correct in that Boxford used a Coventry quick change tool holder and then added a pull stud to it
    I have the dimensions to make some side lock tool holders but I can’t find suitable pull studs
    They have an M8 std metric thread so I guess I could turn some my own but as they appear to be hardened I think it would be easier all around if I could buy the pull studs
    Does anyone have a source for these pull studs or if you good people happen to have any down the back of your sofas then I’m all ears
    Cheers. Paul
    Hi paul I hade the same problem as you so I made my own, If you use silver steel you can harden it your self.
    hope this helps you.
    depronman's Avatar
    Quote Originally Posted by reelman View Post
    Did you make them on a cnc lathe ?
    If so would you consider sharing the G code please
    Many thanks. Paul
    Hi Paul, no I did them on a manual lathe
    depronman's Avatar
    Ha proper old school
    Looks like this is my next programming challenge
    Cheers. Paul
    Just out of curiosity,
    Does Cam bam accommodate lathe jobs ?? or do folks code them from scratch?
  1. WANTED: Boxford Duet tool holders, software and manuals
    By Charles Andrews in forum Items Wanted
    Last Post: 26-09-2018, 12:11 AM
  2. FOR SALE: atc tool holders, 3/4in er25 collet holders x10
    By dazza in forum Items For Sale
    Last Post: 11-03-2015, 10:48 AM
  3. WANTED: BT 35 Tool Holders
    By Sparky in forum Items Wanted
    Last Post: 08-01-2015, 06:34 PM
  4. Boxford VMC190 Retrofit Problems, axis sounds very rough
    By mikegolding in forum Boxford Vertical Mills
    Last Post: 09-06-2013, 09:11 PM
