Page 3 of 7 FirstFirst 12345 ... LastLast
  1. #21
    Link to information that recommends a DC power supply for the servo driver?
  2. #22
    No such thing, it was my assumption, so in other words I don't need any PSU at all, just plug the drivers directly to mains?
  3. #23
    Read the specification for you selected drivers.
    You will always need part for control logic, switching etc., but if you have mains driven servo drivers then this would be a much smaller power supply, at lower voltage and power.
  4. #24
    ah, that makes sense, okay, thanks.
  5. #25
    Some servo drives need only a AC supply, others need AC + 24V DC for the control logic.
    In all cases you will still need a DC supply for the motion controller and other things. Basically a small switching PSU like this: https://uk.rs-online.com/web/p/din-r...plies/0428477/
  6. #26
    gone
  7. #27
    Why direct drive?
    Won't it be much harder regarding drawbar etc?
  8. #28
    gone
  9. #29
    The Z looks complex. I assume you have a complete machine shop to build it. Ideally it should be as wide as the gantry carriage.
    I would go fixed gantry for the relatively small working area you planned.
    Maybe also consider simplifying the shape of the columns, but in the end you'll be the one to build the molds :)
  10. #30
    Quote Originally Posted by jarjar View Post
    I do not, all I have is a hand drill and a dremel, I'm outsourcing it. The sheet metal cutting and welding. It's not more complex then a straight or a C plate. It's just a square steel tubing in the end. I've actually received a quote for the whole piece from the local shop EUR600 total for the thing.
    Besides the Z, nothing is final yet. I'd go with a fixed gantry but I haven't got a clue yet as to how I'd deal with the bed. What I mean by that is I want to be able to mount the 640x320 work piece vertically. With a moving bed, I don't have any ideas how to do that though.
  1. Big Epoxy Granite machine, Which frame is better ?
    By EZELab in forum Gantry/Router Machines & Building
    Last Post: 18-09-2020, 10:18 PM
  2. BUILD LOG: Epoxy granite vertical mill build log
    By Nick in forum DIY Mill Build Logs
    Last Post: 08-06-2020, 05:30 AM
  3. Large Format Epoxy Granite Gantry CNC - Looking For Feedback
    By Max Maker in forum Gantry/Router Machines & Building
    Last Post: 23-08-2019, 03:57 PM
  4. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 05:21 PM
  5. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 06:28 PM
