27-11-2020 #21
Hi Jazz - hope all is good. Sorry to thread hijack, just read your comment about the 230V pump - while running mine today I remembered I'm still using one of those potential death traps with no earth submerged in coolant! From what I can tell (no details with it) its probably 3000L/Hour flow rate .
Do you recommend a better 230V pump or 12/24V versions? Thanks
Ryan
27-11-2020 #22
Ok thank you that was very helpful, i will do more research, as far as the motors can you recommend me any closed loop steppers that are cost effective? i am still planing the build but looking in to maybe buying a used/ ebay custom steel frame so just looking for how much steppers ect will cost me so i can price it all out
thanks again Tank
27-11-2020 #23
i have found these steppers here (https://www.omc-stepperonline.com/ye...nd-driver.html) they are closed and not to expensive, are they any good?
27-11-2020 #24
They are ok but again they are only 50V drives and this will limit the speed/torque.
But today could be your lucky day.!! . . . I've just received a shipment of 50 sets of Lichuan Closed-loop steppers. 4.5nm and 5.5Nm that use AC volatge. A large number of these are allocated to machine builds but I have about 10 sets spare that I would be willing to sell.
https://www.aliexpress.com/item/1005...74663421I66r5w
I also have Ethernet controllers from CNC DRIVE that I would sell. I have AXBB-E and UC300ETH with the UCBB Breakout board. Also can provide UCCNC license files at extra cost but lower than you'll pay elsewhere.
In a few week's time, I'll also have 2.2Kw spindle kits. Similar to what you were looking at with Huanyang VFD etc.
PM me if you are interested.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
27-11-2020 #25-use common sense, if you lack it, there is no software to help that.
27-11-2020 #26
ohh awesome will pm now
27-11-2020 #27-use common sense, if you lack it, there is no software to help that.
Welding gas advice needed
By cropwell in forum Welding, Brazing & EquipmentReplies: 10Last Post: 08-07-2025, 06:37 AM -
Needed some advice, please.
By PLIP5 in forum General DiscussionReplies: 3Last Post: 29-07-2018, 07:45 PM -
Advice needed on everything
By chrisjames in forum General DiscussionReplies: 12Last Post: 11-11-2015, 11:40 PM -
NEW MEMBER: Hello guys im a new member from the uk and looking for advise
By charlieallshapes in forum New Member IntroductionsReplies: 3Last Post: 05-10-2015, 08:20 PM -
NEW MEMBER: hey guys, help fom experienced fanuc controlled cnc programmers needed. thanks
By benread89 in forum New Member IntroductionsReplies: 1Last Post: 18-08-2011, 04:20 PM
