Thread: Mach 3 homing issues
	29-11-2020 #1Hey guys, im going to try and explain this the best way I can so bare with me.
 When I make a cut on my cnc I'm usually using multiple tool paths one after the other with a tool change for each tool path, so when I start mach3 I jog to the centre of the workpeice and home it a couple of inch above where I need it to be and the dro then reads zero on all axis but on one of my other jobs I accidentally saved fixture when I shut mach3 down, so now when I try to set my home position the dro doesn't zero itself. Can anyone help me reset my home position?
	29-11-2020 #2Never mind i fixed it lol. Panic over
	29-11-2020 #3Hi Richard,
 I know you sorted it but do you understand how it happened.? If not then I'll explain why if you like but before I can do that properly I need to know if you have Home switches fitted.?-use common sense, if you lack it, there is no software to help that.
 Email: [email protected]
 Web site: www.jazzcnc.co.uk
  About homing and switches...By JW1977 in forum General ElectronicsReplies: 39Last Post: 09-09-2019, 09:16 PM
  CNC first setup homingBy Gary1329 in forum General DiscussionReplies: 1Last Post: 30-07-2019, 11:40 PM
  Mach 3 Turn - CAM IssuesBy Chaz in forum CAD & CAM SoftwareReplies: 9Last Post: 07-08-2017, 05:16 PM
  A Cunning Plan For Accurate Homing With Mach 3?By magicniner in forum General DiscussionReplies: 8Last Post: 04-04-2016, 01:48 PM
  Problem with homingBy Andyman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 22-03-2016, 07:56 PM
