Thread: Machining rubber
20-12-2020 #1
I need to make some parts from some reasonably hard (shore 80A) rubber, just wondering how possible it is to machine it? Anyone ever tried it? It would save a lot of time and money over moulding them.
20-12-2020 #2
A Long time ago I machined some 10mm thick rubber gaskets for a vacuum tanker and it went well enough but I think the thickness helped and it was reasonably hard stuff. Used a single flute cutter and cut in one pass.
If it's thin stuff I think I'd use a board on top to hold down and cut thru both at the same time.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
20-12-2020 #3
can you freeze it ?
20-12-2020 #4
20-12-2020 #5
That's a good suggestion, however I don't have a fridge in the workshop (it's quite cold enough as it is to not bother about food going off
), but I guess as long as I'm quick I could stick it in the freezer at home and give it a quick squirt of aerosol freezer when I get in.
20-12-2020 #6-use common sense, if you lack it, there is no software to help that.
22-12-2020 #7
I thought rubber was usually ground so I just googled rubber grinding and there it was
22-12-2020 #8
20-01-2021 #9
I cut some polyurethane at 30000rpm with new, razor sharp 3 flute HSS cutters and oil free flood coolant (I've done some with air too), around 1mm DOC per pass, the parts were 10mm wide 1.5mm wall tyres for a steel tape labelling machine, they came out really nicely.
There is no good, useful info out there on machining rubbers and polyurethanes, most of what has been offered is misleading or unhelpful, like "freezing" ;-)You think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
21-01-2021 #10
Thanks for the advice. BTW, what diameter cutters were you using please? - it would be useful to get an idea of a workable SFM.
Rubber/plastic flexible strip for swarf exclusion
By Voicecoil in forum Swarf & Chip ManagementReplies: 7Last Post: 12-09-2019, 12:04 AM -
RFQ: Need something machining?
By HiltonSteve in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-09-2018, 04:47 PM -
FOR SALE: Open End 3M HTD Rubber belt 15mm wide
By wiatroda in forum Items For SaleReplies: 0Last Post: 22-06-2011, 03:49 PM
