Thread: G-code Error ?
    cpf's Avatar
    Lives in digbeth birmingham, United Kingdom. Last Activity: 15-01-2021 Has been a member for 4-5 years. Has a total post count of 12.
    Would some one be able to inform me if there is an issue with this g code ? I am simply trying to cut a board a metre up and it is cutting at 80/90cm . When looking at the drivers they read ER 020. Looking online this seems to be an error in the G code. Once the Y axis drivers show this error code the Y axis does then not move.
    T1M6
    G17
    G0Z20.000
    G0X0.000Y0.000S22000M3
    G0X0.000Y1013.175Z6.000
    G1Z-4.333F3000.0
    G1X1220.000F4000.0
    G0Z6.000
    G0X0.000
    G1Z-8.667F3000.0
    G1X1220.000F4000.0
    G0Z6.000
    G0X0.000
    G1Z-13.000F3000.0
    G1X1220.000F4000.0
    G0Z6.000
    G0Z20.000
    G0X0.000Y0.000
    M30
    Type of Machine ?
    No tool offset that could still be active with a radius/diameter number in it ?
    cpf's Avatar
    we have a CNC superstar
    ZASto's Avatar
    Lives in Belgrade, Serbia. Last Activity: 3 Weeks Ago Has been a member for 5-6 years. Has a total post count of 49. Received thanks 1 times, giving thanks to others 1 times.
    That smells as the servo following error.
    Check your Y axis for binding.
    G-code looks normal, I can't see no errors in it.
    Cutting in X direction 3 passes, total depth of 13mm.
    cpf's Avatar
    Thanks for checking that for us ! it seems to be the the y axis is for some reason not working correctly. its reading that it meets its limit but it under the limit by about 12cm. does any one know how we can reset the home and resolve this ?
    ZASto's Avatar
    What controller do you use on your machine?
    Settings of the controller?
    You know, my crystal ball has not returned from polishing, yet
  1. repeating code error
    By motoxy in forum Programmers Corner
    Last Post: 28-02-2014, 07:51 AM
  2. VFD problems, please help. error code DL
    By humbo3d in forum Spindles & Drive Motors
    Last Post: 09-02-2014, 08:10 PM
  3. VFD problems, please help. error code "DL"
    Last Post: 06-02-2014, 05:49 PM
  4. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  5. Mach3 + 2010 Screenset crashing. "Error found , Art Code: 9988"
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 11-06-2012, 02:44 PM
