Thread: My new machine - Guess the make!
I've been on this forum since April 2020, asked a few daft questions, got my head around what I'm after and have recently collected and set up my new machine.... Maybe you know the chap who made it?..... Goes by the name Jazz something or other.....
Anyhow, after many lengthy emails and conversations discussing needs/wants type of build, this Jazz bloke who also likes to be called Dean has rustled a few part together to produce my first CNC. Feels solid as a rock and weighs more than one too. Me and 3 mates were at our limit lugging this brute into my workshop.
Just like to say a massive thanks to Dean for all the info, the 4 hours I spent with him 'upt North showing me the ropes. Has got me off to a cracking start and he is a top bloke to boot. I'd gladly recommend anyone chatting to Dean to see if he can build something to their needs. Can't see you going wrong really with the knowledge he has.
Anyhow, here are a couple of pics and I even tidied my workshop up all special like.
The Following 4 Users Say Thank You to Pilsbury For This Useful Post:
I surely hope that you sent him box of PG tips he will appreciate that. 🤔😊🔥
06-02-2021 #3-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
07-02-2021 #4
Too clean
Thanks for posting Pilsbury. As someone somewhat further down the waiting list for one of these machines, I was hoping to get an early glimpse of one on this forum.
Certainly is tidy. But please we want more......photos, video, impressions. Good luck as you take your first steps into CNC
07-02-2021 #6-use common sense, if you lack it, there is no software to help that.
08-02-2021 #7
Ok then, more photos coming soon as I’m mid way cutting my first “proper piece” 😉
But some first impressions. Heavy. Very bloody heavy. Sure Dean may correct me, but my guess is 400kg. All parts are heavy duty, either thick steel box section for the frame or milled aluminium....guessing over 1/2” thick. Totally rigid which is key to accuracy and decent cuts. Ploughs through the wood I’ve presented it with and I bet I’m cutting conservatively. Can cut aluminium as shown by Dean’s test piece he gave me. I’ll save aluminium for a later date. Electrics wise, I know little about, except to say the electric enclosure is neat, tidy and well laid out. Certainly not a worm’s wedding!
I’ve had zero mishaps, no broken bits, no issues at all and I’ve done a fair bit of cutting now. But that must be down to my extensive CNC experience (5 hours) 😉
Perhaps tomorrow when I’ve finished my current piece, I’ll post some photos of my efforts so far. Promise to be gentle.... I’ll also some more machine photos
The Following User Says Thank You to Pilsbury For This Useful Post:
08-02-2021 #8
Don't really get the gist of what your meaning by this Rob.?
Erm, I'm struggling to see any correlation Kit other than both use Steel and water-cooled spindle.?
Well, Solid Works say 265Kg but I've got a feeling that was calculated using a 3mm wall tube and we have used 4 and 5mm with a scattering 10mm steel plate for things like gantry sides. The aluminum parts are a mixture of 10mm, 15mm, and 20mm. I'm thinking the extra 100kg+ discrepancy could be the powder coating...
I haven't actually weighed a finished machine yet because soon as they are finished I'm trying to get them out the door, just don't drop it on your toe is my advice...-use common sense, if you lack it, there is no software to help that.
09-02-2021 #9
Dean,
I was, as usual, being slightly facetious, your standards and mine are very different for good reasons. But the key point I had in mind is...
I can't see this for certain but it looks like the fixed rails, leadscrews and motors on each side are all fixed to a single beam which allows adjustment of the rail spacing without upsetting the relative alignment of those elements. It also makes the machine simpler to disasemble for transport and instalation without upsetting the alignment, a factor which would be important if the workshop is in an attic as this one looks like it might be from the photographs, though I wouldn't want to carry 400Kg up the stairs, even in several pieces and I certainly wouldn't want to sleep in the bedroom directly underneath it!
I built my new steel framed machine in this way after having endless problems getting everything lined up all at once on the last of my wood and MDF versions.
Pilsbury,
Brilliant video! I also like the credits, though you might be in trouble for leaving out "Post Production Catering - Wife" if you have one and she brought you a cup of tea during the editting.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
if the workshop is in an attic as this one looks like it might be from the photographs,..Clive
How tricky would this be to machine? I guess a Triac is not up to the job!
By suesi34e in forum Metalwork DiscussionReplies: 21Last Post: 15-06-2016, 05:11 PM -
NEW MEMBER: CNC wanabee I guess.
By aliasant in forum New Member IntroductionsReplies: 2Last Post: 07-11-2014, 10:34 PM -
plasma advise sought, want to make a a3-a2 sized machine
By nobby in forum Plasma Table MachinesReplies: 1Last Post: 16-07-2014, 02:53 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
RFQ: help needed to make cnc machine maybe 2-3 and will pay
By scnc in forum Projects, Jobs & RequestsReplies: 10Last Post: 22-11-2012, 12:31 AM
