Page 2 of 2 FirstFirst 12
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    Thanks, Ive just read his Denford Mirac refurbishment thread but couldn't see what the white paint was.
    looking at his work I think it will have to be sprayed tho rather than hand painted, looks like new.
    He's had a few different threads, but I can't remember what thread paint types were discussed on.
    I'm pretty sure he does spray most stuff, but with a bit practise and the right paint, you can get a good finish without having spraying.
    I'm leaning towards the single pack enamels like Tractol at the moment and may try roller first to see what the finish is like.
    Because I haven't been able to get it blasted im a bit concerned about the rust. sanded and scotchbrited but obviously its still there in places. Is it worth spraying with cold galvanised first to seal or just use red lead or the products primer.?
    You could use some rust converter.
    I've used POR15 metal prep in the past, and if you can keep the rust wet for a few days with occasional agitation, it will dissolve all rust.
    It'll even dissolve rust in pores that blasting can't get to.
    Alternatively if you can find a suitable container, a few hours electrolysis will also dissolve rust.
    I have been looking at the POR 15 products and they have been recommended a few times.
    I've seen a few machinery enamels that can be thinned by white spirit, and are much cheaper. Are these likely to be as hard wearing as the other enamels?
    Also looking at PPG selemix 7-610, as I think I can get that locally, its a synthetic enamel so the thinner is pricey, but cant find out if it is oil resistant for the using flood coolant.
  5. #15
    I've had some reasonable results painting stuff myself, but the most durable results have always been when I've been able to dry the paint at elevated temperature or used 2 pack formulations.
    Was that a 2 pack epoxy or enamel? any product names?
  6. #16
    The 2 pack I've used is polyurethane - great stuff BUT YOU MUST WEAR APPROPRIATE PPE WHEN SPRAYING otherwise you will be really quite ill for a long time. I can't recall the manufacturer of it (was a few years ago), but seem to remember that it came from Germany. I've never used the epoxy myself, but a friend did and said it gave a very durable finish. Some quick googling turned up this stuff which seems pretty reasonable: https://www.taindustrialpaints.co.uk...pular-colours/
    I've found drying at elevated temp. helps with pretty well all air dry paint types whether it's enamel out of a tin from the local paint dealer or even stuff in an aerosol: I don't think it's by chance that a lot of industrial finishes are referred to as "stoving enamel". Mind you the weather is generally cold and damp up here, not the best conditions for drying stuff.
  1. Lathe ATC Options?
    By Ross77 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 28-08-2020, 12:13 AM
  2. 4th Axis options?
    By Ross77 in forum General Discussion
    Last Post: 13-01-2020, 04:31 PM
  3. Fed up with Mach3 - what options do i have here??
    By Davek0974 in forum Bridgeport Milling Machines
    Last Post: 22-04-2018, 06:49 PM
  4. PC Upgrade Options?
    By Chaz in forum General Discussion
    Last Post: 31-08-2016, 04:53 PM
  5. ATC Options?
    By Davek0974 in forum Gantry/Router Machines & Building
    Last Post: 14-05-2016, 08:25 AM
