Page 2 of 2 FirstFirst 12
    Nut would appear to be similar apart from the radiused sides, is there room for this . What is the damage to the screw, can't see any in the pics
    NO switches are not fail safe, I never use them as limits or in ES positions
    Yes there is room for the radiused sides, and the damage was to the plastic part holing the bearings in place. I have tried without success to repack the bearings but even with carefull assembly its got very tight spots.. and the plastic sleeves on the lower part are damaged..
    Yes I understand my switches wer'nt fail safe and seems my soft limits didnt help.. As far as Im aware I think one of my sons had been using the machine or maybe from a broken wire on the switch ( not set up diffrently) ? An in my error I didnt check things before I used it (rush job) :(
    OK will try to get it machined this weekend
    How much ? ect and thanks
  5. #15
    Have sent PM
  6. The Following User Says Thank You to johnsattuk For This Useful Post:
  7. #16
    pm sent
  8. #17
    Many thanks for the help from johnsattuk saved the day... I am now up and running
    amazing help when needed most :)
  9. #18
    Quote Originally Posted by flotsam View Post
    New to the forum, came here because everything else seems US based and not always the best place for advice.
    I run a 3040 cnc ballscrew version and use it to make parts for model ships.
    Now I have just run into what could be best described as a bad issue..
    I have a damgaged Z axis ballscrew that needs replaces (endstop switch failed.. Broken wire)
    Now I;m having issues find a UK supplier of 150mm SFU1204 12mm Ballscrew. I mean no where can I find one.. ?
    I know the UK no has issues with the brexit situation but heck ,, Im at a loss..
    anyone know who would have one ?
    Can I suggest something?
    Wire your safety circuits as Normally Closed. If a wire breaks the switch will go open and shut it down.
    Food for thought.
  10. #19
    Already done that now thanks .... all NC
  1. NEW MEMBER: Hello everyone, bespoke spectacle maker in London pulling my hair out.
    By Worshipfulspectacles in forum New Member Introductions
    Last Post: 23-11-2019, 02:33 AM
  2. pulling my hair out with cam
    By universally in forum CAD & CAM Software
    Last Post: 09-04-2015, 01:41 PM
  3. Hair growth device. DIY version
    By gavztheouch in forum Electronic Project Building
    Last Post: 30-03-2014, 08:55 PM
  4. AM882,s and Mach3 ......plus hair removal !!!
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 26-10-2012, 05:11 PM
  5. Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
    By fasteddy in forum Motor Drivers & Controllers
    Last Post: 14-05-2010, 02:32 PM
