    Rojo's Avatar
    Lives in South Chailey, United Kingdom. Last Activity: 04-07-2021 Has been a member for 8-9 years. Has a total post count of 2.
    FADAL VMC15 CNC VERTICAL MACHINING CENTER
    see this facebook link to see pics ( https://www.facebook.com/marketplace...5-71220f45521a )Attachment 30172Attachment 30172Attachment 30172
    Year 1995
    Serial No 9412523
    Fadal #88HS CNC Control
    Table Dimensions 16" x 29.5"
    Table Load Capacity 750 LBS
    X axis travel 20"
    Y axis travel 16"
    Z axis travel 20"
    Spindle taper BT40
    Spindle Speeds, Range 0-7500 RPM
    Rapid Traverse Rate 400 IPM
    Tool changer capacity 21
    Tool Change type Carousel
    Spindle Nose to Table 4" to 24"
    Spindle CL to Column 17"
    Tool Diameter, Max 3"
    Tool Length, Maximum 15"
    Tool Weight, Maximum 15 LBS
    Feed Rate, Range .O1 to 250 IPM
    Weight approximately 5500 LBS
    Coolant Flood
    Rigid tapping Yes
    Expanded memory 384k
    Comes with 17 LAIP tool holders, all of which are usable but have minor corrosion on them due to the poor coolant mix from the previous owner. Also has the original users and maintenance manual. The coolant tank, pump and grills are included but just not in the pics.
    As can been seen by the pics the machine has been well used but the work it did was of a light nature making electrical faceplates and engraving in thin gauge aluminium and plastics.
    The mill has been run up and works as it should, I have partially cleaned it but it could really do with having a deep clean as I did on my own machine, cleaning was not a strong point with the previous owner. Any inspection / test is welcome.
    The mill is currently located at my work RH17 West Sussex UK
    Looking for £3500
    Collection to be arranged by the buyer, you will need a lorry with a hiab for transport, will move to a suitable place for collection.
ID:	30174   Click image for larger version.
  1. CONVERSION: Poorly N sick Fadal 15 VMC Will live again!
    By JAZZCNC in forum Conversion Build Logs
    Last Post: 10-04-2022, 06:02 PM
  2. Replies: 3
    Last Post: 21-11-2019, 08:51 PM
  3. NEW MEMBER: Devon, UK. Fadal VMC15 10k 4 axis. Faulty VGC. Light work. Stood for 8yr.Sale/Break
    By spaaz in forum New Member Introductions
    Last Post: 21-11-2019, 03:09 PM
